Aussieveedubbers · Business Advertisements
New RHD Type 3 Dashboard skins ~AUS$140
https://forums.aussieveedubbers.com/threads/91321/new-rhd-type-3-dashboard-skins-aus140
67fastyrsa ·
Hi gents,
G'Day from this side of the Atlantic.
I'm eben, the founder of the South African Aircooled VW forum and I just wanted to post this as info you yourselves, as I am doing to most " RHD" forums...
One of your members have started a run of new dash covers for Type 3's.
It might not be in everyone's taste but if it is, here is the info...:
http://www.aircooledvwsa.co.za/viewtopic.php?f=72&t=20365url
VW Type 3 RHD Dashboard Skin $139.55 The dash is made of 3 mm UV-stable, leather finnish, ABS Installation instructions will be sent with each unit. Will be bubble-and-cardboard wrapped. Please note the Dashboards are sold as seen on photos, what you see is what you get. So please look at the photos, and satisfy your self if you want the dash. The dash has been made to the CAR size, so approx. 6 mm bigger then most SUN burnt dashes that have shrunk in the car over years. This means, that you can fit it over your old dash, to give you bulk. (prevents it sounding hollow if tapped) OR... You can fill the inside with foam spray, OR..... You can fit it as is. If fitting over old dash, you may have to trim old dash on a few spots to slide it over. If filling with foam, place "cling wrap" over steel dash after removing old dash, spray a small amount of expansion foam into back of NEW dash, and press into place, hold still for as long as can recommends. Do not bee concerned if foam flows out all over, let it dry, and break or cut off, remove cling wrap, and fit dash. You may order your dash UNTRIMMED as per these photos, and you cut them out as you want. This is the best option if you are a perfectionist. Alternatively you can get them trimmed by the factory that make them, please note that there may be some places that you would want to file. Please use a steel file, not a carpet knife, as one slip, and the dash is damaged. Link to article that gives more information: http://www.aircooledvwsa.co.za/viewtopic.php?f=72&t=20365 Package size: Untrimmed: 1430 mm(l) x350 mm(w) x 170 mm(h) Trimmed: 1430 mm(l) x 170 mm(w) x 170 mm(h)
PS: I am not selling these myself but I am helping by providing an online store for orders....
Eben
