Aussieveedubbers 路 Tech Talk
type 4 oil coolers
https://forums.aussieveedubbers.com/threads/9136/type-4-oil-coolers
Starbug 路
having a look at this months volks world mag... good article on getting more cooling from your oil cooler. the thing is, how hard is it to get a type 4 oil cooler?
KruizinKombi 路
Not too hard, I've got two 馃榾
Try dropping down to your local wreckers. They shouldn't cost too much (they don't look very impressive) but they are a pain to get out, you have to remove a few things before you can get to them. You might be able to buy one from a VW specialist out of a broken motor.
Craig Torrens 路
broken motor ? just watch out for broken motor bits in cooler !馃榾
Would be best to get a cooler off a motor that is already running , if poss.
Starbug 路
:thumbThanks guys馃檪 I was hoping id get those responses and not "your dreaming!"馃榾馃榾
I was of the general impression that type 4's and type 4 bits were hard to get? perhaps i am thorougly mistaken馃檪
Bizarre 路
Starbuggy wrote:I was of the general impression that type 4's and type 4 bits were hard to get? /quote]
Type 4 the car - yes very hard
Type 4 the motor - no was also in 1974-1982 combis
Not as common as the common as muck Type 1 but still easy-ish to get
Yoy have to modify you fan shroud to put it on. As it is wider you need to cut and widen the cover on the back
jakriz 路
I've done the type 4 oil cooler trick before & so has my father, & for the hassle it's not worth the effort. The temp guage didn't change & the shroud ends up hard up against the fire wall.
After all the effort a simple external cooler is the only way to go.
regards
Jak
