Ok, as some of you know I'm about as clued up on this stuff as my 3 year old grandson, so bear with me, after the Bugs and Busses by the Bay outing last week I am back on the idea of twin carbs on the buggy (thanks Mick and Scott and a few other fellas there) long time ago I had been told that there was no room under the back of the wench to fit the twins so I had discounted the idea but the fellas there pointed out that if I used Type 3 inlet manifolds then I can fit the twins, from there there was several sugestions regarding the type of carbs to use but I have since been wondering why I don't just fit a pair of Pict32's (or whatever), so now I need you fellas to tell me why not. 馃お馃檯
donn 路
Too hard ?
Bizarre 路
Why??
If it is street use - twins are ok
I "believe" twins are not the go for off road use??
Too much slosh is what I have heard
I know you can get stubby Type 3 manifolds for IDF Webers but all up I doubt you will have change form a grand
As for the 32's - I think it is a case of too old, no gain, too much to rebuild
Guess it comes back to why
Post a pick of the rear of the buggy
matberry 路
Why would duals slosh more than a single off road?? Slosh issues comes down to the type of carb. I'd say it's mainly to do with hassle of linkages in the dirt and grime and air filter location is bad news with any dual carb off the shelf system. Use awesome an air filter system and/or remote mount the filter into clean air and no problem.
As for the 32's, same answer, why? go Kadrons as the first step, IDF's as prefered IMO.
Bizarre 路
matberry wrote:Why would duals slosh more than a single off road?? .
Just from my readings at AC.net and other places
I have no experience at bajas and the like
here is an exanple......................
OFF ROAD APPLICATIONS
90% of the time, off road applications should use a centermount system. Why? There are a couple reasons. The first is simplicity. Dual carbs require more complex linkage, and when you are talking about off-road use, this is just more parts to break or give you problems. In addition to this, dual carbs are mounted on the outside of the car, where they are vulnerable to getting hit with debris. Lastly, a carburetor mounted in the center is going to get bounced around less then if it's mounted on the outside of the car as the car is pitched side to side. Therefore, fuel control is easier (less chance of flooding) with a centermounted carb. The power difference between a centermount and dual set-up is very small, and with the above noted advantages of running a single, it's an easy decision to justify. If you want corroboration, just have a look at the winners of the SCORE races and then check out the induction systems installed on the winning cars...
donn 路
Thanks for that, so far as I knew twins would give me a bit more low down and I thought maybe just use the standard carbs (pict 34, I wasn't too sure what is on the motor now), after spending the afternoon with a couple of fellas with some knowledge of these things I have opted to stay single 34 as it's for road use not off road and the engine is stock. It seems I may need a different air filter as the one that is on it may be too small, a few other things to sort may make a difference. 馃檮
grumble 路
Fair decision Donn I have fitted and used a lot of twin setups over the years when I was a little younger, strombergs, nikki dual throats ,solex's, webers and a few more,more often than not they took a lot of setting up for little return in regards to performance or economy with the associated problems .As age and experience comes into the equation .We had a lot of great experiences with these but now I am running a single carb on the Ghia and enjoying it a lot more than working on the side of the road Cheers Les
matberry 路
Mmmm interesting, many variables with that statement. Pitch center of the vehicle, type of bump encountered etc etc. Next sentence says there's little difference between single and dual hp figures .... go figure ?馃
One thing I forgot to mention which is proberly the most important (a post above made mention of it), offroaders tend to build for torque and SINGLE carb setup will have more bottom end torque than duals.
donn 路
Is there any advantage in using a different type of carb, ie, duel throat over single, solex over webber etc?
matberry 路
donn wrote:Is there any advantage in using a different type of carb, ie, duel throat over single, solex over webber etc?
A lot depends on the exact engine combination, but in a nut shell, a single dual throat will definately outperform a single single throat in my experience. A single DCN is ok, a Zenith 32 NDIX is better, for a small engine at least. They both have thier drawbacks though. The DCN suffers from BAD flooding issues when at angles or cornering/braking etc, the Zenith is old and has an old style acc pump system that I could do without, but they are really the best for smooth delivery at all times.
I'd go IDF , a 40 or even 36 for a small engine, and 1900 upwards a 44, esp with a mild cam and preferebly some head/chamber work (naturally 馃檪 )
ANY single NEEDS an effective manifold heating system to operate properly in all temperature conditions IMO.
donn 路
So there is one of my problems I believe, though I came to that conclusion some time back, my manifold has no provision for a preheat as is on the engine I have waiting patiently for me to decide where to go with it (procrastination, the theif of time ) so looks like I'll have to chase down another manifold unless there's onother way of heating it.
Bizarre 路
some people say the electric manifold blankets work
I am not one of them
matberry 路
The easiest option to try is to use warm carb intake air, ie a snorkel or pipe picking up used cooling air or a pickup near an exhaust port to the air filter surround. VW did this from early on, and also had the manifold preheated with the exhaust. Problem is it all starts to look pretty ugly. And a summer winter switch would be best....
