Aussieveedubbers 路 Tech Mods and Frequently asked Questions
IRS conversion to Oval floor pan issues
https://forums.aussieveedubbers.com/threads/91435/irs-conversion-to-oval-floor-pan-issues
retroresto 路
Hi Guys,
I've converted the gearbox from swing axle to single side plate IRS, i've mounted the trailing arm brackets etc and everything is fitted. The issue i have is the CV joints rub on the engine mounting forks, can this be cut out and if so will it compramise the strength of the forks? Can i simply heat them up and pound them down? whats the best plan of attack here? Anyone?
Paul
Adelaide
STIDUB 路
heat & hit with your favourite FBH 馃檪
or, cut minimal amount out & shape a section to replace that hugs the CV
depends how much work you want to do, most ive seen/heard of are heat & hit jobs though
Aussie Dubbin 路
Yup Heat and HIT, use a bar that will give you a nice shape though, Stops all the little hits that will look crappy.
retroresto 路
Looks like the Hammer gets the Job! Thanks guys for your advice... I should of known, when all else fails hit it with a FBH馃槀
vlad01 路
I have always wondered about that especially when using 930 CVs. Thanks for the posts guys. 馃憤
Brad 路
Don't forget to weld up the side of the forks once you have hit them as they will open up, rust and split. Also remember to modify your shock towers as the IRS arms will hit on up travel and if you have stock rear brake lines on them they will get squashed.
matberry 路
On ya Brad
definately cycle suspension and clearance the shock towers.
Aussie Dubbin 路
Have i missed this one... Bugger hope not i have just finishe dpainting my whole pan... What part of the shock towers have you clearenced???
retroresto 路
Good call Brad, just notices some marks on the shock mounts that were caused by the spring plate bolts hitting them. Im guessing i can just clearance that area out with a grinder?
Also hadn't thought about the brake pipes either, thanks guys
Do you think it's neccessary to have some sort of mount/support to support the forks in the event they may be weakened by the flatter forks?
馃憤
