Hey all.
Is an air/fuel ratio gauge a worthwhile investment?
What exactly are they for?
And what is the difference between wideband and narrowband??
Smiley 馃槑
Smiley 路
Aussieveedubbers 路 Tech Talk
https://forums.aussieveedubbers.com/threads/91448/airfuel-gauge
Smiley 路
68AutoBug 路
Joel 路
Smiley 路
Heated sensor?? More info?Joel wrote:I had one when i was setting my blower up, narrow band ones aren't that effective on a carbed car.
If you get one make sure to fit a heated sensor.
matberry 路
Yes, but that depends on whether you wish to watch the A/F ratio, it will show up a change in A/F ratio. ie. a blocked jet or manifold leak etc.Smiley wrote:Are they more a gauge to help with tuning then pretty useless after that??
Smiley 馃槑
ratty 63 路
Joel 路
More or less what Matt said.Smiley wrote:Heated sensor?? More info?Joel wrote:I had one when i was setting my blower up, narrow band ones aren't that effective on a carbed car.
Smiley 馃槑
Sides 路
Thinker 路
Smiley 路
Hey Matt.matberry wrote:Yes, but that depends on whether you wish to watch the A/F ratio, it will show up a change in A/F ratio. ie. a blocked jet or manifold leak etc.Smiley wrote:Are they more a gauge to help with tuning then pretty useless after that??
Smiley 馃槑
Wide band has a much broarder range, a narrow band is useless in comparison, but they are the first generation that is used in many efi factory systems to moniter and adjust the A/F ratio.
I use the Innovate Motorsports LM-2 with good results so far
RISKY4LIFE 路
Joel 路
Smiley 路
matberry 路
Yep, but I've actually got the one below as a workshop tool, it data logs and hooks up to a laptop....among other things 馃檪Smiley wrote:Hey Matt.
Is this the gauge you're talking about??
http://www.innovatemotorsports.com/products/MTXL.php
Smiley 馃槑
