EJ-15 engine specs wanted
https://forums.aussieveedubbers.com/threads/91468/ej-15-engine-specs-wanted
krusher74 ·
Hi, I have a EJ-15 engine from a Japanese impreza, i have a friend with a computer program that can calculate exhaust size/length but I need detailed engine specs for the cam/ valve sizes etc.
Anyone know where I can get an engine spec sheet?
Is it carbed or fuel injected?
Not gospel but a bit of info anyway
Displacement: 1493 cc
Bore: 85.0 mm
Stroke: 65.8 mm
Compression Ratio: 9.4:1 - 10.0
Valvetrain: SOHC
Fuel Delivery multi point fuel injection
EJ151
Horsepower: 97 PS (71 kW; 96 bhp) @ 6000 rpm
Torque: 129.4 N·m (95 lb·ft) @ 3600 rpm
EJ152
Horsepower: 102 PS (75 kW; 101 bhp) @ 5600 rpm
Torque: 136.3 N·m (101 lb·ft) @ 4000 rpm
EJ153
Horsepower: 95 PS (70 kW; 94 bhp) @ 5200 rpm
Torque: 140.2 N·m (103 lb·ft) @ 3600 rpm
EJ154
Horsepower: 100 PS (74 kW; 99 bhp) @ 5200 rpm
Torque: 142.0 N·m (105 lb·ft) @ 4000 rpm
krusher74 ·
Joel wrote:Is it carbed or fuel injected?
Its is the much more modern FI unit used in the Impreza in japan till 2005.
I have the info you posted (thanks anyway)
But its cam and valve specs etc I need.
seagull ·
Base line is so close the EJ16 your fart will make o difference
you will still lean forward going up a hill with this donk but fit a SC super charger to it, there is youtube links to this
krusher74 ·
seagull wrote:Base line is so close the EJ16 your fart will make o difference
So what are the ej16 stats for the question I asked?
krusher74 ·
Ok me back again, turned out the my contact had all the info for 2008 on subaru engine, so I still need the specs for the EJ15, any one know a good subaru forum worth asking this on?
