Aussieveedubbers 路 Tech Talk
Dizzy Installation
https://forums.aussieveedubbers.com/threads/91479/dizzy-installation
smithy68 路
Probably a common silly question, got my new SVDA distributor , trying to install it but when I try to insert it in to the motor the seal seems extremly tight.
I have lubed with petroleum jelly but it is still extremly tight. Do I need to do anything special?
matberry 路
Just take your time and use lots of applied force. Sort of like a hard day dropping the kids off at the pool, push hard, relax, push hard, relax....continue until the seal is in 馃檪
smithy68 路
Ok, well time to start pushing, then relaxing, thanks Mat 馃檪
greedy53 路
a bit of oil helps
68AutoBug 路
smithy68 wrote:Probably a common silly question, got my new SVDA distributor , trying to install it but when I try to insert it in to the motor the seal seems extremly tight.
it most probably will cut off the top of the o ring...
Mine did... lol
Just forcefully push it down...
or tap the top of the shaft with Your Hand
I also used lots of oil on the shaft and o ring
also don't forget to oil the distributor too
Smiley 路
DO NOT HIT THE TOP OF THE SHAFT!!
The O-ring is on the housing and the shaft is only attached by bearings. You could damage your dizzy by hitting on the shaft.
One thing I do is to make sure I put the dizzy locking clamp on to the dizzy then put the O-ring on afterwards. This is because the clamp has quite a square sharp leading edge on the hole where the dizzy slides through, and if you force it through here you can cut the O-ring. Whereas the engine block has a small taper to help lead the O-ring into the whole without cutting or damaging it.
So clamp on first then O-ring! Then as above with the firm force.
Smiley 馃槑
matberry 路
Smiley wrote:DO NOT HIT THE TOP OF THE SHAFT!!
Smiley 馃槑
Good advice there Smiley. I also make sure the hole in the case is smooth, but surely the dizzy is in by now !!!
68AutoBug 路
Yes
always clamp on the distributor shaft first
and open the gap with a large screwdriver can help open the gap
makes it easier...
VolksVair 路
Doesn't one wonder if the aftermarket dizzy have an aftermarket incorrect size "O" ring?? I would piss off the o ring and install an original vw "O" ring, still will need to lubricate/grunt & groan. But no where as bad as the fatter aftermarket o ring.
smithy68 路
It's all good guys just took some firm pushing, just to make sure I pulled it back out to check the o'ring etc then put it back in.
Thanks for all the responses.
