Aussieveedubbers 路 Buying, Selling & Swapping Parts
WTB (QLD) - Type 3 Wide 5 Rear Brakes
https://forums.aussieveedubbers.com/threads/91489/wtb-qld-type-3-wide-5-rear-brakes
Smiley 路
Hey all
I'm looking to do an IRS conversion on my Baja. And I'd love to get some Type 3 Wide 5 rear brakes to put on it.
I'm chasing everything required for the conversion -
-drums
-backing plates
-springs, clips, plates etc from under the drum.
Wheel cylinders and shoes aren't so important as I'll buy new ones.
I'm located in Yeppoon, Central Queensland
Post reply, PM me on here or
Phone Daniel on 0488572493
Smiley 馃槑
ancientbugger 路
Hey Smiley, check out Dune buggy and baja adventures website 'cos Mike Sharp has the complete set up for sale,
Barry
P.S. He's in Toowoomba Qld.
Calcool 路
Why not just put a wide 5 rear disc set up on, all new for under $500 from Classic Veedub.
Otherwise you can use all the hardware from any type 3 for backing plates shoes springs clips etc and then buy new drums, they are available from parts shops from time to time they are danish made I beleive.
David
Smiley 路
Calcool wrote:Why not just put a wide 5 rear disc set up on, all new for under $500 from Classic Veedub.
David
Correct me if I'm wrong but I don't think these kits are ADR approved and therefore not legal?
Smiley 馃槑
grumble 路
I have a couple of sets of type 3 4 stud rear brakes if you need them.PM if interested
Smiley 路
grumble wrote:I have a couple of sets of type 3 4 stud rear brakes if you need them.PM if interested
Thanks a heap for the offer Grumble, but I'm really chasing the 5 stud if possible.
Smiley 馃槑
Calcool 路
I think you are going to have to get a mod plate when you do the IRS conversion anyway, and you should get the brakes approved while you are at it, the type 3 wide 5 rear drum will have to have the cone machined down too so it will fit on your stub axle! Not exactly a bolt on job. Believe me I have done it myself.
David
11CAB 路
The drum only has to be machined if you're putting them on short axles
Smiley 路
11CAB wrote:The drum only has to be machined if you're putting them on short axles
I'm changing to IRS in a few weeks.
Smiley 馃槑
Pete 路
I have a pair of brand new type 3 drums in stock if you want them...... wide 5 pattern
