splitty rear brakes
https://forums.aussieveedubbers.com/threads/9150/splitty-rear-brakes
type82e ·
I need some splitty rear brakes its for a 65 "big nut" gearbox I have the backing plates and drum but no shoes, springs, clips, cylinders etc
do brakes from a later bay fit on as i have a 77 kombi wreck
do shoes and other bits from an earlier splitty fit ie 36mm "small nut" gearbox
marcel
Desert Bug ·
Marcel,
the '77 shoes etc. should fit but the early ones wont as they are smaller diam. and narrower. I saw you were looking for an axle nut the other day, use the ones of the '77 there the same size thread but different shape nut (better).
Ian.
[Edited on 7-8-2003 by Desert Bug]
type82e ·
thanks desert bug lets hope that works
now i just have to get a 46 mm socket and t handle
marcel
type82e ·
apparently the brakes fron any kombi 64-67 (splitty) and early bay to 2/70? are the same so anyone out there have any lying around just the rear shoes springs clips and cylinders etc?
I can have the shoes rebonded no problems just need the cores
marcel
