F/S (QLD) PORSCHE FAN SHROUD+ SCAT IDA MANIFOLDS/INJECTORS AND FUEL RAILS/CUSTOM EXHAUST SYSTEM FOR TURBO SET UP COMPLETE WITH
https://forums.aussieveedubbers.com/threads/91521/fs-qld-porsche-fan-shroud-scat-ida-manifoldsinjectors-and-fuel-railscustom
LIFE IN THE LOW LANE ·
Porsche fan shroud to suit big capacity type 1 modified to fit on Auto Linea case. Modified to fit around IDA manifolds etc etc. Also modified for cyclinder head temp sensor etc etc. Shroud only no mounts etc.
Was on Troy's Type 3 but no longer needed due to engine going into drag car.
$200 or nearest offer
Contact me via pm or email - kombiking74@hotmail.com
Cheers brennden
Payment via direct deposit or cash if in brissy. Will freight interstate at buyers expense.
Scat IDA manifolds ported and flowed, dowelled to get perfect fit on ports on heads.
Injector bosses positioned in base of manifolds to squirt straight down the ports into combustion chambers.
440cc GTR Skyline injectors(new $100 each)
Fuel rails to suit.
$450 for the lot.
Payment details as per first post.
Cheers brennden
Selling due to new buying new heads and manifolds.
typethreeking ·
These items are from my fastback, engine has been removed to go into my new drag car so selling off what i dont need.
Complete stainless steel custom exhaust system for turbo set up on type 1 including turbo and wastgate to fit into Type 3. Fabricated by Custom Exhaust Specialists.
Package entails -
1.5" primaries tuned length
10mm flanges
one slip joint on whole system ( and it doesn't leak!!)
Tail pipe and screamer pipe HPC coated
2 exhaust housings - .6 housing and .8 housing
split pulse entry on exhaust housings
T3/4 Garrett turbo with modified wheels (turbo needs rebuilding - shaft bushes/seals etc)
6 bolt flange on exhaust side instead of usual 4 bolt flange (better sealing)
45mm external wastegate with screamer pipe
$2000 or nearest offer
cheers Brennden
Brenndan, PM sent re fan housing
