When i got my case machined i got them to install helicoils on all studs (I had a few that spun when undoing the heads originally).
I have screwed them all in but some seem to screw in a bit deeper then others, and when undoing bolts they spin out.
Now before i start bolting the heads to 28ft how do i ensure that the studs are in as far as they are meant to go? I tried the double bolt method and almost stripped the thread.
Anything i can try?
Thanks in advance.
Brian ·
Case savers are better than helicoils,
helicoils can be problems in alloy, thats why the factory used solid steal inserts.
What size are the studs 8 or 10 mm ?
Thinker ·
If helicoils are fitted correctly they shouldn't move
johny rotten ·
whatever🤪
eraser ·
sorry yes i meant case savers, i couldn't remember exactly what they were called.
Maybe i should just try the double nut approach again, but i do have a question on how to i undo the second nut as it tends to get real tight.
