Aussieveedubbers 路 Tech Talk
Weighted Pulley
https://forums.aussieveedubbers.com/threads/91597/weighted-pulley
Smiley 路
Is one of these weighted pulleys a worthwhile addition to an offroad vehicle?
I've just purchased a new engine and need to add a pulley to it. I was looking for a replacement sand seal so I can run the kit I have on my current engine when I stumbled on this.
http://www.vwparts.net/MB16-9700.html
More rotational inertia should give better low down torque correct? Or is it not the norm to run one of these unless you have a lightened flywheel??
Smiley 馃檪
68AutoBug 路
I believe they just balance the crankshaft better...
Maybe they are used mainly with counterweighted crankshafts??
Still sounds like a good idea... [like two flywheels}
Old Dubber 路
I would like to see some facts and figures
more weight means more energy to turn it
just my opinon
matberry 路
Bergs recommendations are to run the extra weight on a C?W crank and lightened flywheel. The extra mass is to help absorb engine harmonics. Proof.....dunno about that, although I would use one esp. with an extra light flywheel. What engine combo have you bought?
Newt 路
I would have thought that if it works as advertised (remembering that most cars on the road have harmonic balancers), then wouldnt it be more beneficial on a non c/w crank.
ie - Doesnt a C/W crank already help with the vibration / haromincs issue.
Newt
Smiley 路
matberry wrote:Bergs recommendations are to run the extra weight on a C?W crank and lightened flywheel. The extra mass is to help absorb engine harmonics. Proof.....dunno about that, although I would use one esp. with an extra light flywheel. What engine combo have you bought?
It's a 2054
94 bore and 74 stroke.
Los Panchitos Heads
Scat C20 cam.
Twin 40mm Kads.
Just thought it might help with some low down pulling grunt. I don't have a lightened flywheel and I don't really intend on running one.
Smiley 馃槑
matberry 路
Smiley wrote:It's a 2054
Los Panchitos Heads
Scat C20 cam.
Twin 40mm Kads.
Smiley 馃槑
Woo Hoo 馃憤 you wont no yourself 馃檪. Sounds like a good combo. In that case, if you like it, I'd go for it. The mass won't hurt the baja and steel wont wear quickly like the non-annodised alloy ones.
Smiley 路
Los Panchitos Heads
Scat C20 cam.
Twin 40mm Kads.
Smiley 馃槑
Yeah. I'm super excited. I can't wait to get it in the car.
I think I'll get one. I've heard they are meant to help reduce harmonics or something too? And if it helps engine life and runs smoother I'm all for it.
Smiley 馃榾
