Beam narrowing?
https://forums.aussieveedubbers.com/threads/91599/beam-narrowing
roofchop ·
Hey guys,
I have a 67 beetle, 2"dropped spindles,Wide 5-205's with 145/65/15's and just about to fit beam adjusters...
Before doing the adjusters I filled the load area with about 100 kg of sand bags to see how it will look...
Looks great but I will still get tyre contact on the guards when on full lock.
So I thought I would narrow the beam 2".
Looking at it now the shock towers are nearly touching the inner guards so if they move in an inch the guard will have to cut/modded, also ithey will be right on the edge of the fuel tank!
Is this normal for a mere 2" narrowed beam?
What am I missing here?
Thanks in advance
Dave
roofchop wrote:Hey guys,
Thanks in advance
Dave
I think that's correct Dave
that's why I don't like them...
the other way....
is to adjust the FULL lock on each side so the tyres don't touch...
even with those small tyres on the front..
You may need to heighten the front slightly...
or use wheels widened on the outside...
hellbugged ·
http://www.btinternet.com/~aircooled/wolfsburgeast/beamnarrow.html
roofchop ·
Thanks for the replies,
That link is the go, I will do exactly that, cheers Hellbug!
Dave
roofchop ·
Thanks for the offer turbo66, I really want to do it all myself.
(I can't PM yet)
Dave🙂
roofchop ·
Just thought of another issue...
I have an anti roll/sway bar (just fitted new bushes...what a pig of a job!)
How do you go about shortening that/
I'm guessing just straightening one end then re-bend 2" in.
The question is to cold bend it or heat it up....cold it may snap, hot it may loose its springyness?
what have you lot done?
Cheers Dave
zayus ·
Hi Dave,
You can buy a 2 inch narrowed front sway bar.
Bugpack - available thru CIP in the US - http://www2.cip1.com/ProductDetails.asp?ProductCode=C12%2D6500%2D40
EMPI - available thru Classic Vee Dub in Sydney - https://www.classicveedub.com.au/cvd_new/part_detail.aspx?parts_id=15072
captainvw ·
2'' narrowed isn't enough for going low (any lower than 100mm) my first beam was a 2'' and it split the outer lip of the gaurd with in a month you can go 4'' with flat style end plated or 4 and a bit with Tin KDF (Bugboy) designed end plates
Ryno17 ·
captainvw wrote:2'' narrowed isn't enough for going low (any lower than 100mm) my first beam was a 2'' and it split the outer lip of the gaurd with in a month you can go 4'' with flat style end plated or 4 and a bit with Tin KDF (Bugboy) designed end plates
Dub beams are the G O. Fitted one to my 61. Wheels don't rub at all and it sits about one inch off the deck. Really strong well made Aussie too!
These beams look great. Saw them in posts ages ago. How much for one?
