krusher74 ·
Hi, has anyone got there subaru swapped vw onto a dyno yet, was just interested to see that number they put to the ground compared to what subaru said that engine put out?
https://forums.aussieveedubbers.com/threads/91636/subaru-swap-on-a-dyno-results
krusher74 ·
seagull ·
krusher74 ·
According the Wiki the ej221 makes 133hp and the Ej222 142hp so your right on the money.helbus wrote:EJ22 in bus
76KW (101hp)at the back wheels.
That would be about 135hp at the engine!
DubCrazy ·
Fastie ·
ian.mezz ·
vassy66T1 ·
Fully Sik. The purists love it!
ratbug ·
krusher74 ·
Cool , so you gained 15hp with the aftermarket ecu.ratbug wrote:My 2.0L EJ20 Quad cam was 110Hp atw stock ECU, 125Hp microtec ECU.
2.0L EJ20T quad cam turbo (legacy RS motor with VF10 turbo and stock ECU) was 175Hp atw.
From experience, all 2-2.2L Ej's seem to produce between 100-130Hp atw, turbo versions 165-210hp from stock to relatively mild mods.
2.5L non turbos don't have that much more hp, but have a fair bit more torque down low.
ratbug ·
Apparently, Was at the same shop on the same dyno. The operator said I could probably get 10-20hp extra with aftermarket ECU... he tuned it and yeah got 15hp extra... BUT i didnt really notice it. It seemed to just have a bit more top end power. Although it had more power on paper it wasnt as good, harder to start, sometimes played up, the tuner wasnt really up on subies.... So when I did my new car with the turbo engine, i stayed with the stock ecu. Sure an aftermarket ecu is better on a turbo, but just couldnt be bothered again.krusher74 wrote:Cool , so you gained 15hp with the aftermarket ecu.ratbug wrote:My 2.0L EJ20 Quad cam was 110Hp atw stock ECU, 125Hp microtec ECU.
krusher74 ·
In simple terms what I have read/heard, is that due to emissions and catalytic converters (and tuning to cover all atmospheric conditions around the planet) most stock ecu maps are set up for stoich 14.6 to 1 fuel air ratio.ratbug wrote:Apparently, Was at the same shop on the same dyno. The operator said I could probably get 10-20hp extra with aftermarket ECU... he tuned it and yeah got 15hp extra... BUT i didnt really notice it. It seemed to just have a bit more top end power. Although it had more power on paper it wasnt as good, harder to start, sometimes played up, the tuner wasnt really up on subies.... So when I did my new car with the turbo engine, i stayed with the stock ecu. Sure an aftermarket ecu is better on a turbo, but just couldnt be bothered again.krusher74 wrote:Cool , so you gained 15hp with the aftermarket ecu.ratbug wrote:My 2.0L EJ20 Quad cam was 110Hp atw stock ECU, 125Hp microtec ECU.
JVLRacing ·
Not the same motor as urs......cause it has 242hp!!Jak Rizzo wrote:Andrew's fastback with the same motor as mine, same Microtech running from memory the stock? 13.5psi boost & slightly bigger exhaust has 242hp at the wheels. Pretty nice for a factory engine.
Jak
seagull ·
krusher74 ·
What is a metal cat? (not that I actually ever want to own a car new enough to have a cat)seagull wrote:I had a metal cat on mine and it helped over the stock cat
modulus ·
max autos ·
seagull ·
seagull ·
