Type 3 auto torque converter oil
https://forums.aussieveedubbers.com/threads/91716/type-3-auto-torque-converter-oil
tweety ·
Never pulled a vW engine out on my own before. Did so today in readiness for the EA81 conversion.
I noticed I could pull off the torque converter easily after the flax plate was detached. There was a little hardened oil around the inside of the bell housing but nothing serious. A few questions...
1/ Does the converter fill up with oil from the transmission? It seems to.
2/ Is it worth renewing the seal that I can see that prevents oil from escaping this area?
3/ If so what would be the best way to do this? dEstroy the original seal or is there a tool for extracting it?
I've started a conversion thread. It might assist trike owners in the future.
mackaymanx ·
The torque converter is supplied oil from the transmission.
Yes replace the seal every time you disturb it, it's fussy.
tweety ·
thanks
and to extract it? and do you use two seals as explained in some web pages?
I was thinking of replacing the seal between the auto tranny and the diff. is it worth doing? Seems like a lot of work there and my aching back!!
mackaymanx ·
Number 20 is the VW tool, so improvise from there.
tweety ·
thanks Mackeymanx.
I was editing with a few more questions if you can take a peak please?
I can improvise the tool thanks again
grumble ·
mackaymanx wrote:Number 20 is the VW tool, so improvise from there.
I used to have a local production of tools with dimensions if you need it I will try to locate it for you. Cheers Les
mackaymanx ·
http://www.ebay.com.au/itm/TOLEDO-OIL-GREASE-SEAL-REMOVER-2-HOOK-DESIGN-310MM-/150562576980?pt=AU_Car_Parts_Accessories&hash=item230e3a9a54
tweety ·
have ordered that handy tool. thanks
