Hi all here are some pics of my brother's Type 3 Fasty with turbo EFI set up. He has just removed the engine from the car to go into his new project a tube chassis drag beetle.
Complete stainless steel custom exhaust system for turbo set up on type 1 including turbo and wastgate to fit into Type 3. Fabricated by Custom Exhaust Specialists. All the hard work is basically done for you. All you need is an engine to handle boost and a gearbox to match LOL. Also have IDA manifolds with injector bosses, injectors and fuel rails which suit this package as well if you are interested.
Package entails -
1.5" primaries tuned length
10mm flanges
one slip joint on whole system
Tail pipe and screamer pipe HPC coated
2 exhaust housings - .6 housing and .8 housing
split pulse entry on exhaust housings
T3/4 Garrett turbo with modified wheels (turbo needs rebuilding - shaft bushes/seals etc)
6 bolt flange on exhaust side instead of usual 4 bolt flange (better sealing)
45mm external wastegate with screamer pipe
$2000 or nearest offer
PM me if you are interested via here or email at kombiking74@hotmail.com
cheers Brennden
LIFE IN THE LOW LANE ·
