Does any one have this? I would like EFI on a 1600 TP and thought this may be the go say Mexicam running gear with a aftermarket controller.
I seem to remember Dave toying with this some years ago? Mitchell
I don't think mexican beetles had EFI??
and most EFI beetles in the USA have been changed to carby and the heads with small valves replaced..
they also had a habit of catching on fire...
but a mexican engine with EFI from something later would probably be ok
waltermitty ·
68AutoBug wrote:I don't think mexican beetles had EFI??
I was also thinking that this could be a viable alternative, http://www.cbperformance.com/catalog.asp?ProductID=278, as it seems to eliminate the need for an aftermarket computer like a Haltech. Anyone have any knowledge of these systems and how they perform?
waltermitty ·
Barls thanks for the links
Cam that alternative is USELESS at least the link is. Mitchell
That wasn't the one, but that's probably a better option.
As I see it the cb kit has been designed to work together. Building a system using the mexibeetle intake system will still need an ecu. You can get a haltech for about $1000. There are a bunch of other parts that will be needed but the big thing is all the dyno tuning that will add cost.
vlad01 ·
what about an MS ecu? aren't they around 250-300 mark?
SuperOwen ·
You dont need a dyno to tune, just add in the cost for a wideband o2 sensor and most systems will auto tune to target a/f ratios these days on the street. Even the cheap charlie Megasquirt system of mine does that.
