Positive Front wheel camber?
https://forums.aussieveedubbers.com/threads/91791/positive-front-wheel-camber
dubai ·
Guys please excuse my drawing but its to give you the idea I have Positive camber on my Front Left Hand Side wheel and it basically just like in the drawing to the same degree. Its something that I need your advice on how to correct or what is the cause?
It think its beyond using the adjusting camber nuts on the link pin fron end but am open to advice i think it must of had a hit in the front but nothing is obvious or bent Also I have a noise that has developed in the front end I am thinking its a broken leaf sping in the torsion beam is this possible? I have replaced tie rods steering rods so its not this. Any input is appreciated.
Thanks Guys
ian.mezz ·
what sort of vw??
you can adjust shims on early bug.
dubai ·
Hey its a type 1 1962 bug tell me about the shims adjustment any drawings or references?
ian.mezz ·
dubai wrote:Hey its a type 1 1962 bug tell me about the shims adjustment any drawings or references?
http://www.historicvws.abelgratis.com/technical/king_pin/king_pins.htm
you have something BENT the trailing arms and stub axles need to be checked in the origional VW jigs
where abouts are you
