Brake fluid reservoir
https://forums.aussieveedubbers.com/threads/91801/brake-fluid-reservoir
ashbaxter ·
Ready to get the brakes working, i've got the reservoir but how does it connect to the master cylinder, hard line, rubber hose, bit of both or what? any photos would be great
thanks
what year model usualy hard and flex lines the rubber is special stuff as well
grumble ·
Ash are you using the standard single master cylinder? This system uses a hard line and flexible hose at each end,the hose is a special exclusively for brakes as most of the other hoses cannot handle the brake fluid.This hose is available from most vw suppliers or if you are stuck let me know as I still have some. Cheers Les
ashbaxter ·
Hi les if you have some of the hard line and flexible hose to get me going I am happy to pay
grumble ·
Is it the single master? I will try to get the Ghia out in the next couple of days and measure uo for you as you obviously don't have the steel tube.Give me a ring I think you have the number. Cheers Les
ashbaxter ·
Yes single master can't find your number can you give me a call 0418689252 or pm when you check it out
You will need an og steel tube IMO as it has a little flare on the m/c end to seal in the grommet properly. The flexible hose used to connect to the res. MUST be brake fluid compatible. Fuel line does not last. I have the flex in stock and may be able to supply a steel pipe too.
ashbaxter ·
Hi Matt can you do the steel tube with the flared end for me
I'll have a look soon, if your in a hurry, give me a call in an hour or two.
grumble ·
Tube in the post tomorrow Ash. Cheers Les
