68 type III tinware question
https://forums.aussieveedubbers.com/threads/91806/68-type-iii-tinware-question
tintoy ·
Hi all,
Does the engine need to be removed to remove the left hand side piece of tinware that is located on top of the engine?
I can remove the right side top and bottom OK but the left top side gets stuck!!!!
I need to remove it to tighten the head bolts. They were not tightend properly on a rebuild!
grumble ·
No with a little ingenuity and buggering it will come out,I have changed a couple of heads over the years in situ.
tintoy ·
I will try again! Thanks for the reply!
bushed ·
68 was a year as well in 1500 beetles getting loose heads and loktite is good as they will come loose again
