I have a pair of the fender mount mirrors but there I need to drill the holes.
Can anyone post a close up photo and maybe some measurements.
kg1962 ·
What year is your Ghia?
Mine's a MY '64 & the mirrors are mounted near the A piller
Is this what you're looking for?
ashbaxter ·
Yes that's it.
Are you in Newcastle? If so any chance I could have a look at your car as I'm starting to put mine together and it would be great to see a complete one and get some photos as I live in Newcastle
Ash
kg1962 ·
Yes I am in Newcastle
Sent you a PM with contact details
kg1962 ·
I have done a little research on where the mirrors should be mounted
I was surprised that my 4 inch thick 1961 to 1965 workshop manual does not indicate where the mirrors are mounted
Below I have pasted in a scanned image from a 1964 brochure & a picture from my MY64 Ghia, which seem to match up
It also corresponds with old pictures in VW Karmann Ghia Gold Portfolio 1955 to 1974
On Samba there is a guide (no reference given) for the mounting position, which seems a little bit lower than the above, but I haven't checked the measurements against my car
karmann54 ·
I've just checked my '63 model. Using the symbols in the above sketch, a=45, b=110, c=34 and d=35 - so basically matches up except for the b dimension.
No idea if it is 'correct' or not, it is a very original car in general.
Angus
norbert ·
From memory the swan neck mirror was an optional extra. So the mounting points will vary slightly between vehicles.
REDKG ·
The dimensions match my car (60 model).The 'b' dimension is important , any further rearwards and you will have difficulty gaining access. You will need to remove the panel inside the guard.
