About 3 mins before arriving at work i pulled up at a set of lights and noticed the generator dash light flickering dimly. It would go away with higher rpms than idle or whenever accelerating.
At work i opened the deck lid and found oil on the left side of the engine, in a smallish puddle. Also notice the case below the oil sensor is also wet just above the yellow tin in the centre of the first pic, but only at the bottom.
By shokwave2 at 2011-07-31
My first thought was a leaky oil sensor, but after looking and touching it, it was dry. I looked down behind the pulley and also dry. The oil must be coming from beneath the tinware somewhere. Looks like i will have to drop the engine to find out exactly where, as i will have to remove the tinware behind the pulley.
Has anyone had a similar problem, or an idea what is causing the leak and gen light to flicker? There was no loss of power or odd noises while driving. Will i have to split the case?
The engine is a 1600 dual port, stock insides, 34 pict 3 carb, and a merged header with phat boy exhaust. Car was?is running great but will not drive until repaired.
shokwave2 ·
