wtb 5 stud wheel spacers empi
https://forums.aussieveedubbers.com/threads/91952/wtb-5-stud-wheel-spacers-empi
esevwbits ·
hi after a pair of those empi beetle 5 stud wheel spacers, they come in at around 12mm each.
require 1 pair.
Thanks!
ben
sydney or pay for postage anywhere
0432490905
Kuchster ·
I have 10mm wide 5 wheel spacers if your interested.
esevwbits ·
ideally i need 25mm spacers. if you could spit out 2 at that size you'd be saving me a huge stuff around 🙂
Kuchster ·
So do you want 25mm for each side, or only one side??
If your fitting rims like excras you will need to space about 25mm each side of the rear which i can supply 2 x 10mm and 2 x 5mm, much better finish on the cut.
esevwbits ·
yup, thats correct, i need 25 per side. i have a pair of those 12mm empi ones - was looking for a second set to keep things the same. but if you can whip some up i can offload these somewhere else.
How much are you after for spacers equating 25 a side?
Kuchster ·
$73 a side for 2x 10mm and a 5mm
Rob
