i have a stack of parts that i no longer need
complete turbo system includes 500hp turbo,primary pipes with 4 bolt flanges(will fit 2 bolt exhaust heads),3" dump pipe with 2 wastgates and blow off valve,mount brkt to bolt to case and a turbo blanket. all the pipes are hpc coated
$1,000 for the lot
drysump pump 3 stage polished recond will drive a mechanical pump off the front or blank it off
$400 ono
billet turbo cam(roller) ring for specs
$300
autocraft 600B flat tappet cam
430 lift, 280 duration,110 lobe c/r
$250
rear disc brake(drag only)
commodore calipers,steel rotors +2 spare rotors
$230
autometer pro control with 2 step
$135
1 set berg swivel feet adjusters
$45
berg collet set+lash caps $25
berg retainers 33dia spring $30
chev retainers 36dia spring $25
shifter vertigal gate polished alloy with g/box rear plate to suit T/1 or T/2 . will need your shift to modify,not for street use only for raised trans setups
email-davelms@bigpond.com or ph-0412447884
stoker 路
