Double seals? type 3 auto
https://forums.aussieveedubbers.com/threads/92037/double-seals-type-3-auto
tweety ·
While waiting for my EA81 to arrive and my broken leg to heal its a good opportunity to ask some questions. Hope you can help.
I ordered two seals transaxle to torque converter (one spare). I am aware of recommendations from some in these pages that when changing the seal from the auto to the transaxle to use two seals because there is room there and they are prone to leak.
Can I use two torque converter seals?
I must say that during normal operation my auto doesnt leak much oil (touch wood) and I've today renewed the pan gasket and cleaned the filter. So am I worrying too much? or would two seals be a good move?
From memory when overhauling the Autos i dont think theres room for 2 seals
If VW had wanted to seals the they would have fitted them or a double knife seal
The problem may be with the rotating surfaces
make sure its smooth and clean and free from any wear marks when over hauling the box
tweety ·
thanks VW54.
tweety wrote:While waiting for my EA81 to arrive and my broken leg to heal its a good opportunity to ask some questions. Hope you can help.
Normally there isn't room to fit torque converter seals and I haven't heard of anyone fitting two seals
just be sure to lubricate the torque converter seal between the lips with ATF... a few drops..
this stops the initial wear of the outer lip...
same as with all oil seals..
tweety ·
thanks Lee
