Aussieveedubbers · VW Circuit Racing
ARDC SUPERSPRINT EASTERN CREEK AUGUST 14th
https://forums.aussieveedubbers.com/threads/92039/ardc-supersprint-eastern-creek-august-14th
bigrudi ·
Still plenty of spaces left Ring ARDC for more details there will be a class u can run in Phone #9672 0208 or down load entry off the cams web site calander of events. or call me on 0418442953 formore details Cheers Rudi
PAZZAN ·
how did u go Rudy
bigrudi ·
not the best of days still sorting the new engine pleanty of carnage on the day 1st heat ss comodore into the wall at the new section at turn 9 on the warm up lap man it was slippery out there 5 major accidents on the day.CAUTION i spun a big end bearing on the 2180 on lap lap 1 of my heat used mahle bearings packaged in yellow and white box[do not use these bearings as they are total crap] have used mahle product for last 10 years with no probs at all, but this stuff is shit in a quality box.Any way other wise it was a good day, rang John laddimatos who was just coming of night shift and asked him if he'd bring his freshly completed but untested L bug race car so we could do some r&d on it as my car was broken.John arrived at about 10am got car scruiteneered no probs fitted some numbers and timing transponder.Car is as fresh as new r spec yokos asked John if there were any instructions just go for it.Took it easy for thefirst 2 lapsto cycle new tyres and just get the feel of the chasis and set up car felt quite good very predictable and consistent ,firstevent forthe car did a best of 1m59 the smile on Johns face told it all,car was running a bit fat so changed the mais to135s yahoo next heat times came down again car ended up runing a1m58 dident miss a beat,ended up running 5th in class 4d sport sedans,many thanks to John Lad Brian Walker and John Molenor running 3rd in class after scraping in with 6points just have to sort out the engine in the sports sedan then we can put some pressure on the leading v8 x ambrose ford au 13b turbo alpha sud and2oosxs Cheers Rudi
PAZZAN ·
bad luck with your car no fun doing to many rebuilds , but good to see John finally getting back on the track, keep it up good to hear the beetles still pushing hard....
Hi Rudi
Bad luck, I always use Karl Schmidt bearings, I've never had an issue.
Good to hear that Johns bug had its baptism.
PAZZAN ·
you might have to think about a dry sump system Rudy you are going pretty quick these days..
bigrudi ·
put the problem down to yellow and white packaged mahle bearings the metal backing on them had crap integrity u could distort them with your thumb and fore finger.Anyway thats racing and i only had 349hp at the wheels with 15lbs boost.Fresh crank crack tested balanced and case buttoned up next round not till october so still abit of time yet,dry sump mmm il give it some thought. cheers Rudi
Camo ·
bigrudi wrote:and i only had 349hp at the wheels with 15lbs boost. cheers Rudi
Holly molly, that is more than most WRX powered VW put out Rudi and I think your car still has a basic VW cased engine (opens a can of worms).
Well bloody done 👍
Kev 😂😂😂
mactaylor ·
that is nice hp rudi must put a smile on the dial!
bigrudi ·
It certainly brings a smile to the dial but also the ocaisional tear haha nearly back to geather again just need to bluprint new rods and crank,Pauly also picking up a late arriving fathers day present from melb for me 2332 or somthing like that once uv gon stroker very hard to come back cheers Rudi
