G50 adaption
https://forums.aussieveedubbers.com/threads/92056/g50-adaption
seagull ·
what are the ratios in the gear bag ?
pete wood ·
Have you looked at Ricola's cabrio? He's using a G50.
I have to say though, it will be A LOT cheaper, easier to fit and almost as strong with a subaru trans. You won't need an adaptor plate either. It will also have the right ratios and LSDs and other hot up parts are more easily found. I spoke to Todd at the nats this year. I believe you can even use an early STi box which would be stronger still. The only reason I'd use a G50 is if I was using a porsche motor.
20bkombi ·
Not out of the Question, you'll have to cut the torsion tube and the floor pan and body, I have a G64-21 in my 76 bus.
http://www.californiamotorsports.net/G50%206%20speed.htm
Any questions , just call. 0402233027 Aaron.
Birdman ·
They are huge and heavy and you will have a hard time getting it engineered in nsw. And about $5k
pete wood ·
20bkombi wrote:Not out of the Question, you'll have to cut the torsion tube and the floor pan and body, I have a G64-21 in my 76 bus.
You'd have to say though, your's is up against some special challenges. 😂
Seriously though, they are bulletproof.
vlad01 ·
what about the early 930 box? they look like they fit better.
http://www.californiamotorsports.net/930.htm
pete wood ·
And only 4 speeds.
vlad01 ·
technically a 2 speed with 2 overdrives 😵‍💫
those 930 engine have some serious torque to turn those gears.
ttriebler ·
Anyway....let me know if you want a 5 speed that fits without cutting to torsion tubes... 😵‍💫
