After chasing an oil leak from an oil cooler seal, i got bored so i thought i'd clean up my engine which i have never stripped down since owning.
I found a bit of carbon build up on my pistons (a couple of millimeters thick!) and heads, and would like to remove it to check for damage so what is the best, safest way without paying someone to do it? Valves will still be attached to the heads.
I've read oven cleaner, diesel, carb cleaner, brake cleaner, metho, etc, but will any of these damage the parts? I've also attached pics so if you see anything unusal in them let me know.
Cylinder 3 & 4 head
Piston 3
Piston 4
Pushrods - notice on 2nd from left there is a mark, this can be felt when i run my finger across it. What could this be from and should i repalce them?
shokwave2 ·
