Battery Size
https://forums.aussieveedubbers.com/threads/92116/battery-size
SebastienPeek ·
Hey all!
I'm curious, to those of you that have connected spotlights and/or have an awesome sound system going on in your bug/kombi/kg or anything in between, what size battery do you have?
My current engine only has a generator, but have bought a 55amp alternator kit to replace this. When I get this, do you recommend I also get a bigger battery or will this fix my issues of too much load on the engine?
My main concern is that if I do, which I intend to do soon, install spotlights on top of my current sound system, that not even the alternator is going to be able to support the massive power drain...
Thanks!
I have always used an EXIDE 52D 470 CCA
The 51 ampere alternator will give You over 600 watts..
I haven't seen a 55 amp VW alternator but maybe they are available.
I always use 55 watt QH driving and fog lamp Bulbs...
the 100 watts is a BIG draw...
it really depends on the Sound System...
I have seen many cars with 75 amp alternators and two large batteries...??
If You turn the sound system UP and the lights go dim...
turn the volume down... lol
PS: You can always add another battery on the other side under the seat...
+ positive to +POSITIVE and NEGATIVE -- to NEGATIVE --
still 12 volts... nearly 14 volts with the alternator running..
SebastienPeek ·
Hey Lee!
I bought this from Classic VeeDub -> https://www.classicveedub.com.au/cvd_new/part_detail.aspx?parts_id=14625
I'm going to see what it is like after installing it and see if my engine doesn't have a massive issue.
Currently, my lights dim when my foot is off the accelerator, and brighter when I accelerate. It is kinda humorous...
I think this is due to the fact that the generator puts out more charge when there are higher revs.
I might consider getting a larger battery if problems still persist.
try cleaning all the electrical terminals with a small file or wet & dry paper etc..
also check out the battery terminals and where the battery earth lead bolts to the body,, take the lead off and wire brush the metal and the lead on both sides...
also check if You have an earth lead going to Your gearbox..
the only beele I have driven that the lights went bright and dim did NOT have an earth cable going to the gearbox [engine] so
it earthed out thru the clutch cable and accelerator cables..
PS: I see the alternators are now 55 amperes.. not 51.. lol
SebastienPeek ·
Thanks Lee,
I'll definitely have a look sometime tomorrow! 😀
The fuse box can cause lots of problems...
the copper ends on all the wires and the fusebox ends all get contaminated over the years and need cleaning..
not forgetting the bits where the fuses fit...
and take the fuse out and bend the tabs slightly inwards..
makes a better electrical contact..
actually, I clicked on Your link to the alternator kit...
then clicked on specials...
and on page 12...
part numbers 113807401A and 113807201B
lots of good specials there.. Lee
ratty 63 ·
As Lee mentioned - I would be looking at your engine/gearbox earth. I can understand the lights dropping in brightness slightly at idle, but they shouldn't change when you open and close the throttle at speed.
I had the same problem with the lights dimming when getting off the throttle with my 78 Kombi, plus the oil temp gauge would vary wildly over bumps in the road - I found that someone had left the gearbox earth disconnected at some point in the past. Reconnecting it fixed both the lights and the gauge issues.
R 🙂
