Aussieveedubbers · Bugs
circlip on thermostat assembly????
https://forums.aussieveedubbers.com/threads/92190/circlip-on-thermostat-assembly
vertex ·
I removed the fan housing from my 58 bug and was wondering if there is a circlip that goes on the end of the thermostat assembly just past the clamp along the shaft. There is a little groove there that looks like it is to fit one but none present. If one does go there does anyone know the size of it.
grumble ·
I assume that this is the throttle ring shaft with the round spring on it,from memory there was a circlip on there and if you should be able to purchase one from Repco or Bursons as a universal type circlip if you measure the shaft size.
vertex ·
thats the one, was going off what the wolfburg west was calling it on there website. thanks for that
grumble ·
The thermostat operates the throttle ring.
