Hi Guys. I am replacing my Groaning 71 transaxle with and older 2nd hand unit. The existing one has one ATF temp sender which goes straight to the speedo light seen here as F13.
The replacement trans has two atf senders, but does not have the switch marked as "3" here as seen on Lees site (68Autobug thanks again!) http://rides.webshots.com/photo/2275221200050767931gqJnCg. This switch is supposedly a selector for two different "drive ranges".
It does have a funny two blade switch when I look up the part number is a reverse switch. Anybody come across a double sensor unit without a selector, and if so, any tips on how to wire the senders to the kontrollerlamp? (little light thingy in the speedo).
I did check Vwar. But could not find it.
Cheers Pete.
chillihilli ·
