Contact: 0401 937 104 or PM
Items:
5x EMPI 8s, 4x130 - fresh powder coat - 4x fitted white stripe tyres. Excellent condition - $500
4x standard Type 3 rims, 4x130 (diff offset than bug) - 4x fitted tyres. Rims in poor condition (not quite round, but no cracks), tyres not roadworthy - $100
SOLD - 2x V-Force adjustable struts (height and camber adjusters), 3 bolt type for Super/L Bug. Oil shocks. Excellent condition. $500 or $600 with 3 bolt hub assembly if required (this includes spindle, disk, caliper - everything you need to swap out). This is a flat out BARGAIN!
1x L-Bug Dash. Has a crack in centre, but it is covered with carpet. Otherwise good condition. $100
1x L-Bug fuel tank. Something rattles inside. Sender was fine when last used. No leaks or corrosion. $50
2x L-Bug doors. No rust. All things work right. Scrapers are worn and drivers quarter glass lock is damaged (still closes just not tight). $150
PENDING - 1x L-Bug steering wheel, ignition black, steering column assembly. Everything works (key included). $100
1x L-Bug bonnet. Reasonable condition. $50
SOLD - 1x Gearbox - never thrashed and last time was in a car did not have any odd noises or pop out of gear. Very smooth. $300
SOLD - 2x CV shafts and joints. Good condition. $50 for the pair.
1x L-Bug standard sway bar. $50
1x S/L-Bug (not R&P) steering box and assembly. Very good condition, pretty much no play. $200
Glass: 1x rear screen, 1x right and left rear passenger. Seals are good and glass is fine. Has professional tint applied. Suitable for all late model beetles. $25 a piece.
Guards: Elephant foot rears $50 each. Excellent condition. L-Bug fronts, slight damage $25 each. All four for $100.
SOLD - L-Bug pan: Battery tray gone (literally). Other than that it has no bad rust (some surface corrosion). Passenger side floor has been replaced. Comes with all rear suspension components including Type 3 torsion bars (if you want to do an IRS conversion). Will not separate. Take it away for free.
All items are for PICKUP ONLY.
Pictures:
EgeWorks ·
