Aussieveedubbers 路 Bugs
ball joint?
https://forums.aussieveedubbers.com/threads/92388/ball-joint
surfpig 路
just a question about the front beam in my bug, probably a stupid one. but is this a ball joint beam?
bajachris88 路
nope 馃檪 Link pin. 馃憤
surfpig 路
ah, rightio.
at first i was thinking yeah link pin, and then i read my manual and it said ball joint.
thanks matey
68AutoBug 路
AND WHILE ITS UP IN THE AIR make sure You grease All the grease nipples with lithium based Moly grease and it will last forever...
surfpig 路
its back down now, but ill do that tomorrow after work. is that some sort of special magic grease?馃槀
68AutoBug 路
Yes
its also the grease recommended by VW
cheap ordinary grease is based on clay or soap...
Lithium based grease stops wear...
its available everywhere and all brands..
its blackish or purplish in color..
its the only grease worth using...
PHAT BUG 路
Don't try to grease your beam as it has no grease nipples, still do the spindles though 馃槈
vw54 路
King n Link
Its very DRY needs a grease
surfpig 路
PHAT BUG wrote:Don't try to grease your beam as it has no grease nipples, still do the spindles though 馃槈
haha yep, discovered that one. all good now nice and greasey.
surfpig 路
rightio, got a pressie in the mail today.
my drop spindles! so now the question is, how easy is it to install these? as in do i need to press anything in? because i dont have that capability and would need to take them somewhere.
anyone have a step by step process of doing it?
PHAT BUG 路
They need to be reamed/pressed. Best to take them somewhere 馃槈
surfpig 路
oh rightio, hopefully ill get it done this weekend. or during the week
surfpig 路
Well I decided to have a go myself, and I've seen people do it, so I just knocked the bushes out and then put them back in te new drop spindles.
All went back together nicely on te passenger side. But when I put the wheel back on I noticed it has a shit load of play in the top like as if the spacers are missing one. But I put it all back together the exact way I pulled it apart.
Tomorrow I'll do the same to the drivers side and see how it goes. And then maybe pull the passenger side apart again馃お
PHAT BUG 路
Did you tighten the link-pins correctly??
surfpig 路
I'm going to have a look at Haynes and see what it says in there.
What do you mean correctly? I put the washers/spacers back in the same order, and then put the pins back in and the bolt slid through nicely and I did them up. That's basically it isn't it?
surfpig 路
cool, turns out i have the wrong manual!
so i called up the mechanic and im going to take them to him to finish it off. and ill install them.
im just getting over not being able to drive!
esevwbits 路
tthe link pin you slide in, make sure you turn it clockwise to tighten freeplay then nip up.
surfpig 路
Yeah mate, all good now just spoke to the mechanic before I did it and now I'm driving around like crazy!
