Has anyone fitted Empi 8's to a super bug and had the ball joint studs fouling on the inner rim when doing tight turns i.e. car park.
If so, will a camber adjustment fix it or is it going to be more complex?
barls ·
how low have you dropped it. i found that any more than 30mm in a drop and you had to trim the bolts to stop them from hitting the inner rim.
Sbug 71 ·
It's not that low at all yet. Planning to fit adjustable struts soon to make it lower. At the moment I think it's had a coil or 2 cut out of it. Any experience with them? Good or Bad?
Sbug 71 ·
The struts I mean; not the coils.
get rid of the cut springs
That is your problem
Get either some adjustable struts or some struts with lowered cups
barls ·
worst way to do it. id do the same as what barry has said.
Sbug 71 ·
I thought that may be the case. I've already got the struts, just chasing down some standard springs to fit them with.
barls ·
hit up grumble he may have a set up there.
Sbug 71 ·
Who's Grumble?
grumble ·
I have a couple of complete struts and a pair of lowered ones,but may be able to pull a pair of springs to get you out of strife.PM if interested
