I am starting to give some thought to the next project, and have been thinkng for a number of years about a 914 2.5 STI WRX, complete with the Subaru 5- speed.
I know that Boof2332 started on a twin turbo project sometime ago, and that this recently sold again.
I have done the standard Google Search and found some information and U-Tube clips on those who have done it in the US, but have not seen one done here in Australia. There is even a conversion kit in the US!
Has anyone here on the Forum done one, or know of someone who has? I am keen to hear of any other's experiences, or even whether anyone is doing these commercially in OZ (which I doubt very much but am happy to be corrected!).
Craig
vlad01 ·
thinking about it, it should be easier than a suby conversion in a bug.
suby box will work correct the right way around, rads should/maybe easier to get air to?
crsedge ·
vlad01 wrote:suby box will work correct the right way around, rads should/maybe easier to get air to?
Given the engine is mid mounted in a 914 (and thus behind the gearbox), why would that mean the suby box would be the right way around? Would it not have a similar orientation to a Beetle?
Craig
vlad01 ·
no its mid engine layout, so the box is the other way around with the bell housing facing to the front of the car.
see in this pic.
ttriebler ·
There are heaps of these completed conversions on 914 world forum. They fit really well and as you say, very simple to do as they are a mid mount. Have a look at some of the great build threads on that forum.
I make the 2WD locking spool, 2WD transmission blank off plate and the subie to vw output flanges that you will need for this conversion, just take a look at www.subarugears.com
The twin turbo one up at boofs that was going to be going in the 914 has been sold but I saw how they did the gearshift rod. Really easy rod that made its way around the bottom/side of the motor/transmission and then had a pivot onto the subie shift rod. Simple and elegant. Best of luck with your project!
crsedge ·
Thanks for the information guys. ttriebler, you were on my list of possible resources regarding this project from my ongoing scanning of this particular topic area on the forum.
Craig
Jak Rizzo ·
vlad01 wrote:thinking about it, it should be easier than a suby conversion in a bug.
Really? but u said in another post
"suby just doesn't excite me at all.
sure they have power but its all up top. I much prefer bottom end"
So what changed your mind. Did u actually go for a ride in a WRX powered vw to find out thats incorrect?
Jak
A 914 would make a great conversion to WRX power, you should also consider a Boxster drive line.
914s have a very cramped seating position, make sure you can fit into one before making too many plans.
vlad01 ·
That would be perfect for me then 😂
the 914 is on my cars to get list anyways 😀
crsedge ·
1303Steve wrote:Hi
Hi Steve,
What would be the advantage of a Boxter driveline over that of a Subaru one that would naturally mate up to a Subaru Powerplant?
Re: fitting in one, I have owned one before so know that it also isn't a problem for me either, but thanks for the heads up! 😎
Craig
Craig S ·
1303Steve wrote:A 914 would make a great conversion to WRX power, you should also consider a Boxster drive line.
I've spent some time day dreaming about this. This is what I was thinking, but please correct me if I'm wrong 🤓
Boxster would require fewer changes because gearbox is right way round and requires no coversion.
No turbo gear required.
It's Porsche so it keeps it all Porsche
Flat six would be nice, and again would stick with the heritage.
WRX would require some conversion parts and fabrication to make the gearbox work correctly.
Need for extra rad for intercooler?
My questions would be:
* Given the name Porsche would be stamped on the block and gearbox, how much more expensive would it be to do a Boxster conversion instead of a WRX
* What would the power difference be? Much would depend on which engine you got (of either variety). From my quick google, the power difference wouldn't seem to be all that big
* What would the weight difference be? Presumably the Porsche would be heavier, but then it would have less accessories than the WRX (turbo, intercooler etc). If total weight of the Porsche was more, would it adversely affect the handling? Would any additional weight blunt any power advantage?
Either way, it would be a fantastic project, and the final product, done right, would be unique and a blast to drive.
The WRX box would also be going in the correct direction as well because the motor would be in the same orientation as that on a WRX.
This 914 has a Boxster motor, it was at the German autofest last year in Canberra.
vlad01 ·
watch out! boxster engines are built out of the factory to explode. The IMS bearing along with a few other factory blunders make these a great grande just like 996 and 997 engines. 😀
If you want a good reliable boxster engine then you better speak to the experts at "flat 6 innovations"
They have collaborated with LN engineering and Jake Raby to produce the most reliable boxster and 996/7 engines on the market.
Should also keep in mind that a boxster engine is about $18k from these guys. Better stick to suby power if you can't afford that me thinks?
vlad01 ·
They are a bastard to assemble and require special tools, techniques etc... which make them expensive.
I am aware of a number of Porsche mechanics who are not big fans at all of the Boxster plant for similar reasons so keen to avoid, but thanks Steve for the suggestion. That car looks very well presented and sorted.
Are there any recent changes to registration for this engine swap that I would need to consider before embarking? I remember reading some time back that there were some developments in this space that may change the ability to register.
Craig
bus914 ·
Don't take the easy option. Do it right and put a V8 in it. From a 928 preferably. 👍
vlad01 ·
V8???
what? why would anyone every want a V8? Especially a 928!
crsedge ·
bus914 wrote:Don't take the easy option. Do it right and put a V8 in it. From a 928 preferably. 👍
Saw a 914 in an issue of Retro Cars with a Chev V8 in it that was said to go like stink. I would also avoid the 928 donk!
Yogie ·
This is one of only 2 factory made 914 V8's and is in the Porsche museum in Stuttgart. It is a bit hard to see too much as it was all closed up but it will give you an idea.
Yogie ·
The ultimate sleeper
ttriebler ·
zzzzzzzzzzzz to the V8 concept.
Whack an EZ30 flat six in it with two snails and you have more torque than the chassis can ever handle.
To be honest - you really can't fit enough tyre under these things as it is - an EJ20T or EZ30 n/a will be tons.
crsedge ·
Yogie wrote:The ultimate sleeper
The ultimate sleeper/STI is my plan, though with GT flares to accomodate wider wheels/tyres and which also add some more shape to the aesthetics 😎😎
Yogie ·
This thread has piqued my interest in the 914. My wife loves them but I used to be take or leave them. Seeing the V8 one was interesting, especially with the subtle flares to allow wider wheels. I had never really thought of doing one though but an STI in one would be mind blowing.
I look forward to the progress on this.
Yogie
vlad01 ·
Raby builds special engine packages just for them, just another path you could take. Type 4 of course 😉
just look at this one go.
waveman1500 ·
The factory engines for the 914 are more than capable of making power. You can either build up a hot Type 4, or if you have a bit more cash then go for the 914/6 option and put in a 911 engine. If you're going to put WRX power in a mid-engined car then you may as well make it a kit car!
lol love to comments in the first link. just what a v8 does to just about every car.😂
pete wood ·
You know, the first gen CAN AM cars were pretty much identical to this. European sports cars with big US V8s. Seem blunt and undignified, but really who cares. They WENT! But yes, it could do with a better box. An STI trans would probably do the trick nicely.
GeorgeL ·
I wouldn't want a Boxster engine in a Boxster, let alone a 914! They tend to shed the plating on the cylinders at about 50K if you get a bad one. Game Over, insert $20,000 to play again.
OTOH, the Subarus are pretty reliable and the conversion bits are available. What's not to like?
vlad01 ·
Just keep an eye on what Raby is going. He is playing with subys now, just another way of diversifying for his company.
I wouldn't be surprised if a bolt in engine trans package emerges for the 914 in the future from his work. My questions is why not a one of his existing type 4 914 engines? Actually not sure if he offers them anymore?
can't you see in that video the 914 flogging all those 911s!!!🤪
micheloaks ·
1303Steve wrote:Hi
Craig S the Booster engined is owned by Pete Shelley in Canberra. Owner of belconnen vw centre. Hell give you the run down on the car an conversion cost.
Why not subi 6 cylinder.?
There is an uber cool conversion of a bus with custom everything - suspension , body interior and 6cyl subie motor with bespoke efi.
crsedge ·
vlad01 wrote:Just keep an eye on what Raby is going. He is playing with subys now, just another way of diversifying for his company.
I certainly didn't find it a bastard to assemble when i built two of them last year when i worked for Raby.
guru ·
How about the Toyota V8?
32 valve, all alloy? Bullit proof.
I had the weight/dimensions of this motor for my 914.
Not much heavier than a Porsche 6. About 15kg from memory.
Spoke to a guy in the states with a 1uzfe v8 in his 914.
Said it was awesome. And the sound of the motor just behind his head was fantastic.
I'll be going this way with mine.
Subarugears ·
Good luck with that, all you will get is wheelspin and/or wheelies.
What is it with people wanting to stick V8's into everything as if it's some sort of Nirvana?
Maybe plan a bit more overall 'balance' into a project with such small wheelbase and light weight so it will be driveable.
Have you ever driven a Manx with even a modest amount of power?
crsedge ·
Hi All,
I have had some email correspondence with Renegade Hybrids as they market a conversion kit for $1995 specifically for the 914 Subaru conversion http://www.renegadehybrids.com/
They have been very helpful, and when asked about the inclusion of a Subaru transmission thought that it would 'stick out of the rear of the car' with fitment issues after locating the engine and trailing arms rearward. They said the engineering to fit the transmission would outweigh the cost, and that the 914 gearbox is more than capable of handling the power of the conversion.
Thoughts?
Craig
I know Boof fitted up a subaru gearbox
guru ·
Subarugears wrote:Good luck with that, all you will get is wheelspin and/or wheelies.
Have you driven/built a sports sedan?
What about a can-am racer?
Look again at the 914. Its not a manx.
I thought you would have tried to sell me a gearbox instead of shafting my research!
OPPS......
Sorry 'bout that Craig, go the 914 box, mate.
Proven, fits & works well.
Subarugears ·
crsedge wrote:Hi All,
Thoughts?
Craig
I don't know what engineering would be different between fitting a Subie box and a 914 box with adaptor plates and what not. The Subie box won't hang out the rear - it's shorter than a Kombi box. The 914 box may very well take the power of your conversion, but what about the gearbox not matching the torque characteristics so well?
Dunno - worth thinking about the whole package and seeing some completed conversions, plus talking to some people that have driven their completed conversions. I think that's the real decider on parts of the project - find out from those that have driven them and see what they think. There seem to be quite a few on 914world,com forum that looked like good conversions.
Subarugears ·
guru wrote:Have you driven/built a sports sedan?
OPPS......
Yep I have actually driven and participated in the build of several sports sedans.
An XD Falcon with 700hp mid mounted 351 and ZF transaxle
A Fiat Topolino with mid mounted Alfa 2 litre, twin webbers etc
An EH Holden with 179 6 cylinder, triple webbers etc
All raced at Wanneroo raceway
I was on the build team of one of the HK Monaros for the London to Sydney marathon.
So yes, I have had some exposure to what's involved in creating and driving a balanced car.
But not a Can-Am racer!! I don't think the OP is stretching quite that far!!!
Clearly a 914 and a Manx are different vehicles to some extent, simply by the fact that the 914 has a mid mounted drivetrain. The bottom of your post however shows you wanting to fit a V8 into a Manx, hence my comment to you about having driven a high powered Manx. A poorly balanced one will drive like wheelspin. Followed by cornering like a 930 turbo Porsche, but looping out even quicker.
I shot down your research (rather than selling you a gearbox) because I don't agree with putting a heavier engine in a chassis that needs so much balance, when you can use a much lighter engine with more power than you'll know what do do with, and retain the ability to use the car well.
If you think fitting a 1UZ to a 914 or Manx is great, then go for it! I had a 1UZ in my Soarer and loved it. That motor is totally over engineered and bullet proof.
I guess I should start working on making the 1UZ adaptor plates now. Hey, that's not such a crazy idea.😎
IanJ ·
The 914 can definitely take the WRX engine and transmission. There are a few in the US and this is the route I am about to go down.
IanJ wrote:The 914 can definitely take the WRX engine and transmission. There are a few in the US and this is the route I am about to go down.
Hi Ian,
What are your plans- an off the shelf kit or undertaking all of the work yourself? Do you have the base vehicle to start yet?
Craig
IanJ ·
Yip. Car has been in my garage for a while now. Just been gathering info/parts. Once I get into it properly in the next couple of weeks I'll start a thread.
Plan is to use Subaru engine and trans with subarugears parts and get a cradle fabbed locally.
crsedge ·
Great news, look forward to seeing it!
What Aussie state are you in?
Craig
IanJ ·
Hi Craig,
I'm in WA (will update profile and avatar in a sec once I figure out how 😀)
Ian
seagull ·
Ian I spoke with Rob, he is will to sell off the gear. I get him to call you
IanJ ·
Excellent. Thanks Neil. Did you get my PM?
crsedge ·
Ahh, I recognise the car in your avatar Ian, not so long ago advertised for sale on this forum and the Australian 914 Register. I thought the same as you, would be a good donor car for this!
Looking forward to your thread, hopefully lots of things for me to learn as still a while off embarking on the same, though have been reading heaps like yourself on 914World Forum. I believe the next issue of Retro Cars magazine will be featuring a 914 turbo as per the current issue's advertising of coming features, reckon likely the Subaru transplant!!
Craig
IanJ ·
The retro cars issue has been out for a little while now. You can get it on iPad or elsewhere if you look around. 😉
