BAJA PROJECT
https://forums.aussieveedubbers.com/threads/92454/baja-project
RodPenrose ·
I have not had the time to complete this thing and would like to pass it onto someone that will finish it . This is a '76 body with a { factory ? } vinyl sliding sunroof on a '68 semi auto chassis that has been converted to manual . There is a 3" body lift kit , a beam extension that mounts the beam 4" forward and 3" down , a 6" wider adjustable front beam with 3" raised spindles and clearanced ball joints . Out back there is a pr of 3 x 3 arms , 30mm short torsion bars and a set of adjustable spring plates . There is a set of spun steel 17 x 9" custom rims with good used 315/70/17 { 35" } tyres . The body needs minor work , the chassis is original and solid , the ground clearance is 22" and the tyres are 5" outside the fenders . All suspension components are new and not yet used , I would like to get $ 6000 for this project , located in Wollongong NSW , ROD , 02-42729920 .
RodPenrose ·
1916baja ·
😂 Thats not a baja Rod, thats a monster truck!
bugzla ·
cant see it getting passed rego in much of a hurry in qld but it would be nice to have up here
pod ·
would be nice with a subi turbo out the back, yeah you would have to jump through a few hoops to get it regoed ,good luck with the sale
5lam ·
Wow!! I had 13" clearance on mine an I thought that was huge!
rose ·
It's a monster, and I have heals on 😂😂
IWL_86 ·
WOWEE thats a biga Baja!!!!!🤓
