10DAK ·
Just fitted an EMPI twin single carb kit to the beetle. Very happy with the result, but some things to be aware of if you are looking at this mod yourself. They supply absolutely everything in the kit, but it isn't a bolt in deal, well it wasn't for me anyhow. Maybe I'm just fussy. The tinware didn't clear the manifolds where they bolt to the head. I ended up pulling the engine to get a better job done. Reshaped the indent a bit deeper and a bit of clearancing with a die-grinder. I didn't like the idea of drilling the aircleaner for crankcase vacuume, so I made some risers for the aircleaners from SS exhaust tube and put the breather in there. The linkage kit does away with the carb return spring bracket, but then the springs pull at the wrong angle near closed throttle, so I just put a locater on the bracket and fitted them back on. Sooo much more drivable now compared to the original single carb.
