Aussieveedubbers 路 Buying, Selling & Swapping Parts
narrowed leaves wtb
https://forums.aussieveedubbers.com/threads/92547/narrowed-leaves-wtb
matberry 路
Cut down your original ones. You probably already have them 馃檪
Governor 路
Easy, just remove an inch either side of your original ones!!!!
bens1964vw 路
vollks.com.au has some
grogy 路
thanks for all the suggestions. i didnt realise the outside locators which are counter sunk into the leaves were done away with on the narrowed beam. so no need to put in new countersunk tabs. so an easy fix ...just shorten leaves.
Kuchster 路
If you dont put in the countersunk bolts and countersink your beam leaves, your arms will fall out so make sure when you narrow the leaves that you also do all the countersinking.
grogy 路
thanks , i must be dreamin
