with the support & backing from Team WPVW , Cindy has decided to come drag racing with 'Billi' her 1965 model rat beetle
for those of you who dont know Cindy , she has been a team member of WPVW for the past 4 years . She raced at Warwick in 2009 in a blue 1973 L-bug powered by a 1776 type-1 engine and also in 2010 in a red 1960 Karmann Ghia powered by a 1776cc turbo type-1 engine
this year Cindy plans to run her much loved 'Billi' at Warwick with a new 2332ml turbo injected type-1 engine
hypo-vw ·
Billi gets 4-wheel disc brakes , a 2" narrowed front beam , drop spindles , a tandem brake master cylinder and all new brake hoses
hypo-vw ·
Billi is back on her wheels and the brakes / steering feel great .
Now the engine & transmission parts start to arrive . WPVW bores the new engine case for the 94mm barrels and the case is clearanced for the 84mm stoke crank
LOWBUG ·
What computor are you running in it Wayne?
hypo-vw ·
LOWBUG wrote:What computor are you running in it Wayne?
hi Chris , we are running a microtec LT-10s ecu which incorporates ignition / fuel management & map sensor for boost .
Love the progress on your bug mate , cant wait to see it run at Warwick 😎
LOWBUG ·
I can't wait to get there either, hopefully all the loose ends should be finalised next week, then onto the dyno.
Are you going to run an intake cooling system on this engine and what size turbo?
13b type 3 ·
i will be cheering for cindy and billi on the side line this year, great job on the build.
looks like you could be up for fastest female with that combo, 😀
and its a cool rat!!!
RISKY4LIFE ·
hell i think she could be quicker then alot of man ...me for one but i think most people will be quicker then me !
i hope you getting you hands dirty for this build!
hypo-vw ·
RISKY4LIFE wrote:i hope you getting you hands dirty for this build!
she surely is mate !! check this out
hypo-vw ·
LOWBUG wrote:Are you going to run an intake cooling system on this engine and what size turbo?
Cindys' engine will be running a CB Performance header , new ceramic coated T-28 turbo and an aftermarket air-air intercooler
rose ·
O crap
will be good to see the rat in the finals
13b type 3 wrote:i will be cheering for cindy and billi on the side line this year, great job on the build.
LIFE IN THE LOW LANE ·
Don't admit defeat yet Rose!! It's all won on the start line with getting the light right!!
hypo-vw ·
orders have arrived from US with engine and transmission parts included
hypo-vw ·
engine assembly starts for Cindys' 2332 turbo injected engine
hypo-vw ·
the bottom end is assembled
LOWBUG ·
Turb oand engine set up similar to mine, cool, good to see the pockets are deep at the wpvw camp. Not much time left to get it going. Another Turbo car on the way, sweet. What fuel are you gonna run it on?
Hey Chris do u have yr Kleenex handy
hows yr car going
hypo-vw ·
LOWBUG wrote:Another Turbo car on the way, sweet. What fuel are you gonna run it on?
after the cost of the build , we were thinking of pushing it as we cant afford the fuel . lol
think we might start a fund-raiser ...... help WPVW get their cars to Warwick
LOWBUG ·
Cars coming along nice, and I've moved on to a mop and bucket
hypo-vw ·
more engine progress for Cindys' rat-look beetle . engine bottom end finished , deep sump tapped for temp sender , pistons balanced
hypo-vw ·
engine assembly completed , now the cooling tin and turbo system will be installed . New oil cooler and CB performance turbo header installed also
13b type 3 ·
Good work guys👍
hypo-vw ·
more progress on Cindys' engine . The turbo header and cooling tin have been fitted and the engine fitted to my turbo oval to check clearances to the rear apron assembly . all looks good
hypo-vw ·
more engine progress . CB performance injector manifolds and rails fitted .intake plenum being manufactured
hypo-vw ·
hypo-vw ·
more progress with Ciindys rat bug . Wiring of the microtec ecu and fitting of all fuel lines ,pump and filter . We found that Cindy is very handy with a soldering iron
hypo-vw ·
hypo-vw ·
engine ready for fitting to Cindys bug . Just have to get the transmission assembled . All fuel hoses and pump in place , all wiring completed in car ( just need to wire engine to plug at firewall ) wastegate and blow-off valve fitted
Camo ·
Man, I want this motor. I love it, well done guys and good luck with it Cindy you lucky girl 😁
Wayne, since you got most of the gear from CB are you using one of their turbos. Also, do you know with the CB turbo exhaust system if it will bolt up with heater boxes or only J pipes.
Thanks and keep us updated, Kev 👍
2442supercharged ·
After a lot of work billi's motor was finally started today. i will post video in the day or two. Now all that is needed is tuning then it will be ready for cindy to drive again. See pictures of Billi's new wheels - Santa was really good this year!!
bugzla ·
awesome cant wait
bugzla ·
hey guys any up dates to this car and the finished product what ignition are you running with this combo
ian.mezz ·
bugzla wrote:hey guys any up dates to this car and the finished product what ignition are you running with this combo
bugzla ·
hey guy what ignition do you run on this motor
2442supercharged ·
We use a msd coil with a electronic ignition kit
bugzla ·
ben was it a petronix unit and the dizzy locked out sorry for all the questions in a build at the moment and weighing it all up was looking at running the ignition through the microtech has anybody used that option on their vw if so what sort of trigger did you use ive got a 2.1 waser dizzy i want to use through the computer
2442supercharged ·
Yeah it was a petronix with a locked 009 we use the microtech for the ignition I will have to check what trigger we use as I can't remember I know it is a Bosch brand. We use the microtech to control the timing curve
1916baja ·
Have a look at Davis drag buggy project... He runs full microtech and a 13b rotary crank trigger sensor.
bugzla ·
thanks guys this has been great cheers would like to know the trigger if poss would be a ignition module we are talking about ben
