Subaru EE20 Diesel
https://forums.aussieveedubbers.com/threads/92814/subaru-ee20-diesel
mackaymanx ·
There is a Subaru EE20 for sale up this way(Airlie Beach). They are asking $9900 for it, new motor from japan with loom and ecu. Purchased for aircraft but it weighed too much.
It anyone is interested I'll post the phone number up.
mackaymanx ·
Now asking $8500. Motor is in Seaforth (just north of mackay)
ttriebler ·
Would love to get one done...but the standard ECU is CANbus...ewwwww...
ratbug ·
ttriebler wrote:Would love to get one done...but the standard ECU is CANbus...ewwwww...
Nothing is impossible Todd, would be a good challenge.
ttriebler ·
I have someone here in Sydney claims to have defeated the CANbus and will soon be able to reflash ECU's to remove the immobiliser and CANbus functions. And he is very knowledgeable. If it comes to be, then there will be EE diesel conversions like crazy.
ratbug ·
Yeah it shouldn't be too hard, just need a "black box" with a canbus front end on it which simulates data on there from the bits that are missing to make the rest of it happy. I have done similar stuff but not canbus, havn't got the time at the moment, maybe one day. My 2008 rexie even has canbus going to the stereo!
Would your mate know how to get rid of the immobilser in the non canbus ones (2004) I have the key, but i'm fingers crossed its the right key for the computer.
ttriebler ·
Yes he claims his reflash will remove the code from the ECU that looks for immobiliser and CANbus on all models, even ones that are immobiliser only.
But not ready for production yet. NEVER count on these things until they actually happen.
vlad01 ·
CANbus ey? The digital cutters I deal with use CANbus for the MC board, BF board and panel communication. The guys in Switzerland that trained me said it was borrowed from mercedes I think?
ttriebler ·
Yeah CANbus is used in heaps of cars these days - it's basically a two wire local area network. Mercs first started using it in 2005 or thereabouts.
vlad01 ·
http://en.wikipedia.org/wiki/Controller_area_network
geebus hell ! up to 70 control units in a modern car! 🤪mine only has 2, ECU and BCM.
matara ·
Could you ditch the ECU and modify a Megasquirt for diesel use?
vlad01 ·
probably?
mackaymanx ·
I doubt it, the Subaru ECU injects four different times for each firing.
mackaymanx ·
Actually 5 times
http://subdiesel.wordpress.com/boxer-diesel/ee20-engine-info/
vlad01 ·
25,200 psi fuel rail pressure! 🤪
Subarugears ·
These EE20 subie diesels can now be run with an afermarket ECU available in the UK for about 1,100 pounds. Use all standard subie sensors except the ECU plug needs to be changed on the subie wiring harness. This opens up a world of possibilities.
vlad01 ·
haha that would be cool seeing a flat 4 diesel vw.
Yogie ·
I just found some specs for both the Subarus these fit in and the engine itself.
http://www.media.subaru-global.com/eng/whats_new/08_03_07_02e.pdf
The engine is about is about 60mm shorter than the EJ20. Not sure about the height or width though. In other things I have read they weigh about 140kg.
I would be interested to see if there are any issues with fitting it in to a beetle as 150 reliable hp sounds nice.
Yogie
Subarugears ·
I reckon no issues fitting it into a beetle. It is more compact than the petrol ones and has the same bellhousing pattern.
You would need to mate it to a Subie gearbox to handle the torque (👍) but it would easily fit under the decklid and have 5 nice gears. The turbo location on the diesels is at the bottom and front (back) of the engine so no more cutting firewalls to fit turbos - it sits where the VW muffler once was so you can fit turbo, cat and muffler all in there.
If someone wants to take the plunge and get a diesel motor and aftermarket ecu I would supply a gearbox just to see it all done and installed. I reckon it would blow everyone away at the nats.
grinderman ·
If you could get the revs down to 2000rpm on the highway, you could easily get 800km from a standard beetle tank!!! With more torque than ANY petrol motor that would fit into a beetle.
matara ·
I think that the turbo sits in the right position but its a bit low. You usually need to shorten the sump, so looking at the turbo/exhaust positioning it might be sitting too low perhaps?
Would love to put one of these in a splitty.
mackaymanx ·
http://boxeer.com/ee20_parts
jamiec ·
One of those into a t3 kombi wasser cooled would be fantastic i think.
matara ·
Another good site with some ECU info.
Subarugears ·
matara wrote:[img]
Because you will need to use a Subaru transmission to hold the torque of these motors, the engine will be around 50mm higher than if using a VW transmission and adaptor plate. This pretty much negates the need for shortened sump, shortened headers and relocating the turbo.
Would love to see one in a splitty, I reckon it would be the perfect combo.
mackaymanx ·
New Pocket Trader came out today, price drop to $7900.
Subarugears ·
Just plugged the figures into Wes' excel dyno. A beetle with an EE20 diesel and Subie diesel 6 speed, fitted with a 4.44 final drive will do a 14.2 sec quarter mile and be doing 1820 revs in 6th at 100kph. Fitted with 235/60/17. Not bad....not bad at all....
Timbo KG ·
Any idea if the engine is still for sale?
mackaymanx ·
Not advertised anymore, was listed on Ebay but did not sell
http://www.ebay.com.au/itm/ws/eBayISAPI.dll?ViewItem&item=270944106272
Try 0418 747751
Flexibledoor ·
Wouldn't the cost of custom fabrication to get a subaru gearbox modified into a vw be prohibitively expensive? Wouldn't it be more economical to get a vw box strengthened to take the stress of the ee20?
mackaymanx ·
What cave have you been hiding in? http://www.subarugears.com/
This would be cheaper and stronger than staying with a VW box
vlad01 ·
grinderman wrote:If you could get the revs down to 2000rpm on the highway, you could easily get 800km from a standard beetle tank!!! With more torque than ANY petrol motor that would fit into a beetle.
why stop at 2000?
go all the way to 1500, its diesel after all
Flexibledoor ·
Under a very cold and lonely rock ha ha!
Never seen his page before, but that looks bloody brilliant!
I retract my previous statement 😁
froger ·
$6900 now and taking offers...
http://www.ebay.com.au/itm/Subaru-Diesel-Boxer-Engine-EE20-Forester-Impreza-Legacy-/270953967060?pt=AU_Car_Parts_Accessories&hash=item3f161d6dd4
Timbo KG ·
mackaymanx wrote:Not advertised anymore, was listed on Ebay but did not sell
Try 0418 747751
Thanks for the update. I really must check here more often. Is there a contact name to go with the number?
mackaymanx ·
I rang him ages back as this is local to me, but I can't remember his name. The number is from the local Pocket Trader where he had it advertised.
Timbo KG ·
No worries. Thanks for the info so far. Wish me luck. . . .
The_Bronze. ·
Very very interesting thread.
I've been keen on this type of project in a Baja with a Subi box.
The cost is beyond me. I did find a motor bit as usual no coinage.
I will chase this up in the future but for now in happy with my 1600.
froger ·
Check this link out .. ECU replacement to run diesels interesting read . There's a video of them dynoing a EE20 also.. Sounds Fat ..
http://www.twinkam.co.uk/shop/page/8?shop_param=
vlad01 ·
lol sounds like just the roller I used to level the ground in my shed. 😀
Yogie ·
Has anyone done this yet? I just found this ad on Samba http://www.thesamba.com/vw/classifieds/detail.php?id=1538444 if anyone is interested.
Yogie
Matt Ryan ·
Here's a subi diesel installed in a T3 synchro. The build is amazing. The guy is going all out to make a bullet proof camper and he has the skills and equipment to do it.
http://www.thesamba.com/vw/forum/viewtopic.php?t=434656&postdays=0&postorder=asc&start=780
Regards,
Matt.
Yogie ·
Thanks Matt. It would be good to see if it has been done in a beetle or ghia.
Yogie
Subarugears ·
Yogie wrote:Thanks Matt. It would be good to see if it has been done in a beetle or ghia.
Yogie
There's one being built at Vintage Vee Dub in Sydney. EE20 and Subarugears turbo 5 speed into a beetle. Long term project though....
Yogie ·
Yogie
Nice. I hope they bring on the photos as they go.
Yogie
Matt Ryan wrote:Here's a subi diesel installed in a T3 synchro. The build is amazing. The guy is going all out to make a bullet proof camper and he has the skills and equipment to do it.
Regards,
Matt.
Damn that turned out sweet...
