binner wrote:Hi ,quick question about shift plate.
Is the ramped tab on the drivers side or passenger side?. I swear it was on the driver side when i took it out.
I'm having trouble orientating it after putting in a short shifter. It is now jumping out of reverse..
thanks in advance.... IC
the ramps on the Lock out plate are on the LHS not the drivers side..
it stops You putting it into reverse without pushing the lever down...
BUT ONLY ON SEMI AUTOMATICS...
the NYLON shifter bush below the gear shifter is usually worn out by now in most cars... its inside the tunnel..
its under $10 for the Nylon bush and clip...
highly recommended You replace it...
its a fiddly job...
the first time You move or take off the lock out plate it can take a lot of tries to get it correct again...
HOURS.... LOL
photo shows location of nylon bushing... Lee
