Lowering rear 1960 Beetle
https://forums.aussieveedubbers.com/threads/92925/lowering-rear-1960-beetle
bitemeoz ·
Gday ok so I have 2.5" drop spindles on the front, going to lower the rear tomorrow from standard.
Question is should I go 2 outer splines or 1. Or go the mixture for an 8cm drop?
Furnish me with your wisdom.
JB
kombibob ·
With just spindles 1 outer should be enough.
Aussie Dubbin ·
Here is an idea that might help some others. 1 Meter of 10 x 1.5mm threaded rod cut into 4 equal lenghts. A bit of copper pipe and some washers and a nut. It enables really easy setting of IRS cover plate. Let me know if i can help.
Aussie Dubbin ·
You might be pretty sorted, but this makes resetting the plates a breeze
