Bigger fuel line, fuel tank feeder???
https://forums.aussieveedubbers.com/threads/93049/bigger-fuel-line-fuel-tank-feeder
Aussie Dubbin ·
How do i go about changing the line in the tank please,
I have just removed the old one and it just looked like two steel washers with a rubber one in the middle, is it that simple? i imagine i just drill out a larger hole in the nut for the larger pipe??
Cheers guys
PS its now 8mm
Aussie Dubbin ·
bump
Gracey ·
Is this what you're talking about?
http://www.cbperformance.com/catalog.asp?ProductID=584
If so the std outlet on a bug is 6mm from memory, twin carb type 3's came with 8mm std, that where I got mine from.
If you're after something bigger, try this;
http://www.cbperformance.com/catalog.asp?ProductID=1709
Camo ·
Aussie Dubbin wrote:it just looked like two steel washers with a rubber one in the middle, is it that simple? i imagine i just drill out a larger hole in the nut for the larger pipe??
Cheers guys
Yeah, that simple if you just want a larger feed from your fuel tank. But then it will be reduced where it meets up with the fuel line that runs through the tunnel.
This now leads to more work and money 😂😂🤪🤪😬😬
