hi all. all advice gratefully received.
I am doing the heads on my 89 caravelle 2.1 injected. and have a few questions.
1. the fuel lines to the injector rails are old, can i just replace them or do i have to buy special ones? do they have to be exactly same length as the old ones? can i flush out the rails as i have had a problem with water in fuel somehow.
2. is there a trick to separating the sleeves from the heads before they slip off the pistons? Do the sleeves have sealing rings around their bases on the block?
3. i think the water pump is original and done 210k. should i replace it?
4. as the heads loosened, water leaked into the block, as I could not open the drain plugs under the pushroods. Seazed up and i did not want to break or crack anything. how can i be sure to have it all (water) our when i go to refill with oil?
Thanks. That is it so far.
Mark Wilson
mjwcookie ·
