Crazy cols clearout.
https://forums.aussieveedubbers.com/threads/93087/crazy-cols-clearout
coletrickle ·
Still sorting thru all the little bits and peices but the main things that have to go are 1954 -2 prefix 30horse engine,gertrag power takeoff assembley(doesn't have the reduction gear assembly at the back)it was modified to run pullys it is still attatched to the -2 engine, it was used to power a sawmill!A couple of 36's suit reco/ parts,1200/1376cc long motor, d series cylinder heads porters to illegal formula vee specs, with pict 30 and scat econo headder it made 48rwhp!1 pr of T1 mayco cast alloy quick release roof racks I belive it's an Aussie accesory?1968-70 1500 t1t, not a bad little car a little rust in lh rear pan area,webasto rag sunroof. Needs tlc.Old magazines, Vw porshe greats,Vw trends, hot vw's,early volks world,Vw power awvs,Testors nitro powered bay window Kombi tether car,mid 70's brand new in box never started still got the orignal bottle of nitro!Flywheels 228mm kombi, 2.1Wasser, a couple of 180mm oring 12volt,misc 36/40hp tinwear,a few factory Vw dog house fans,15 million beetle dash plaque,Porsche 996 l and r side airbags.would idealy like to swap for 2000 996 porsche body bits rh guard h/ lites f and rear bars, engine lid, tail lites and fill pannel,this is all stuff I was planning on keeping, can be reached T rochedale,Brisbane on 0416 099 372 on the weekends no reception up in the hills just random texts
Pumba ·
PM sent.
whatnow ·
another pm.
WHERE ARE YOU LOCATED??
dansdubs ·
Sent pm but you replied with my original message and no other content col ..
Dan
Aussie ·
PM sent re: tinware.
LIFE IN THE LOW LANE ·
He is located in Brisbane south or up in the hills out of phone range.
Wannavee ·
I thought thats what it said in the ad 🙄
Calcool ·
PM sent!
chequer57 ·
Hi what do you mean by "d series cylinder heads porters to illegal formula vee specs"
Regards,
Ian
chequer57 wrote:Hi what do you mean by "d series cylinder heads porters to illegal formula vee specs"
Regards,
Ian
Col has told me, D is the Part # prefix, 'illeagal formula vee spec' means they have been ported beyond what is legally allowed for formula vee racing.
loco-baja ·
pm sent too 🙂
Burrelli ·
Crazy coletrickle has some Porsche Caps forsale to fit Cookie Cutters and Late 15", 16" Fuchs . Good Condition, one with corrosion on the back. Probably 8 out of 10. $125 For the set or $35 each.
The ones you want without the removal holes in the crest.
