All Parts are located in Buderim, Sunshine Coast QLD
Obviously would prefer pick up but I can do postage if you ask nicely.
Prices as listed or make me an offer.
More will be added soon. I am having a big clearout as well as stripping a beetle and a Baja. So if you are chasing something let me know.
Steering wheel, Needs recovering, Takes 9 bolt boss - $10
Uploaded with ImageShack.us
3x Beetle Speedos, all working when removed - $20 each
Stock 60's Beetle shifter and plate with afterrmarket knob - $20
Chrome ashtray in good nic - $5 SOLD
12v Coil and bracket - $free SOLD
Brand new late beetle front indicator rubbers and housing, 1 missing the top screw. no lenses (well u can have the second hand one thats in one if u want it) - $15 SOLD
[IMG]https://img825.imageshack.us/img825/1030/008lw.jpg[/IMG]
German 009 Dissy, Came off a running motor 2 years ago. needs new points and a clean - $30 SOLD
6V beetle Flywheel , Great condition, will need clutch surface machined as always - $30
Sachs 6V beetle clutch, pressure plate and throwout bearing. used for 6months before going 12V so much meat left - $50
12V Clutch plate, has surface rust but is basically new - $10
Genny Pulley - $5
Kmart spotties 50Watt globes i think - $10 SOLD
Side mirrors, used but still reasonable - $5 SOLD
60's Beetle Dash Pieces with Trim - $5 SOLD
[IMG]https://img850.imageshack.us/img850/2268/017ly.jpg[/IMG]
Chrome low set air cleaner - $5 SOLD
[IMG]https://img31.imageshack.us/img31/4699/018es.jpg[/IMG]
Brand New 009 Dissy Condensor - $Free if you buy the Dissy SOLD
Swing axle beetle (Short Axles) Flexible brake lines, Brand New - $10 SOLD
Coil Clamp and 60's fuel tank lid - $free
30pict 2 Carbies x2, Sloppy, Suit parts or full rebuild -$5ea BOTH SOLD
Good 60's QTR windows, no latches, Small rust spots - $5ea
[IMG]https://img59.imageshack.us/img59/1706/024tju.jpg[/IMG]
Speco Fuel Guage with under dash mount - $20
[IMG]https://img560.imageshack.us/img560/9756/025is.jpg[/IMG]
Under dash Gauge mounts, Fit the little ones - $offers
Amps gauge - $5
[IMG]https://img405.imageshack.us/img405/4095/027wa.jpg[/IMG]
Northstate Mechanical Oil Pressure gauge and sender with idiot light, I also found the oil line and fittings -$10 SOLD
Oil Temp Gauge - $5
[IMG]https://img849.imageshack.us/img849/761/050qx.jpg[/IMG]
Stock 60's Fuel Gauge - $10 SOLD
VDO Amps Gauge - $15 SOLD
VDO Clock - $10 SOLD
Little plastic Spotlights - $Free SOLD
RAMFLO aircleaner, Complete, Bit rusty maybe paint it? - Free SOLD
[IMG]https://img546.imageshack.us/img546/7866/032mt.jpg[/IMG]
EMPI go fast pedal covers - $free SOLD
Half a Genny Pulley and a Genny Brush cover - $free BRUSH COVER SOLD
Bolt on rocker covers, have the extender nuts, Missing one bolt (Standard bolt). - $20 SOLD
Brand new 60's Tail light rubbers - $5
NEW STUFF ADDED!
Genny Stands with Oil fillers - $10 EA
Early 60's Shifter and plate - $20
1500 Dissy - $30
Oil bath air cleaners (2 different types) - $10ea
71 Superbug Speedo - $20 SOLD
Coil with bracket - Free
2x Brosol Fuel pumps (First to buy gets the spacer plate and rod - $10ea
Beetle Brake fluid resovior single circut - $5
2x 60's Beetle headlight dimmer kick switches - $5ea
60's Beetle Ignition switch with key (Non origional key 馃檨 ) - $15
60's Beetle Fuel guage - $10
30 pict 2 carb, Sloppy but better than the other 2 suit rebuild or parts - $5 SOLD
30pict 1 , Someone has macgyvered the choke to work with a manual cable, not too bad play wise - $10 SOLD
Beetle dipstick - $5
Beetle throttle cable tube and stock spring with origional clip - $5
30amp Bosch Regulator $5
60's Beetle steering wheel, Needs restoration, horn ring broken - $free
GC non doghouse fan shroud - $15
30amp Genny and pulley with spacers and fan etc - $30
[IMG]https://img713.imageshack.us/img713/4204/049sl.jpg[/IMG]
Nicko
0439737762
Anthiron 路
