Eccentric camber nut, forward compared to rearward
https://forums.aussieveedubbers.com/threads/93301/eccentric-camber-nut-forward-compared-to-rearward
Aussie Dubbin ·
HI Guys,
those of you that have played with your camber adjustment, obviously moving it outward as far as possible gives you the greatest negative camber, but what happens when you move forward in rotation or rearward in rotation. Can you help me understand what is going on with the wheel.
I have bent top arms, BJ, extra eccentric camber adjusters and looks like 4-5* neg camber at the widest adjustment.
PS if anyone has set their own wheel alignment at home that would be helpful info.
Aussie Dubbin wrote:HI Guys,
the camber adjusters move the wheel in and out at the top
as You know..
its odd [to Me] that these are ..
fitted in the same spot.. with the mark at the front...
so, they are made to be fitted in one position only...
as if the adjuster if adjusted differently the track also changes
[distance between wheels][and that sides wheelbase]
its quite easy to see how they work by turning the adjuster while looking at the top of the tyre or side of wheel
You will see the wheel moving in & out...
I have another front end with adjusters to fit to My beetle
and I've had the extra camber adjusters for many years...
as I have positive camber on one side and negative on the other side.. hopefully the new front end will fix My camber problems..
PS: I wrote this an hour or so ago.. Lee
I didn't answer Your question
When You move the adjuster so the mark is at the rear
the ball joint moves about 10mm more to the FRONT....
once You get the camber fixed up...
to adjust the front wheels...
put a white mark in the center [approx of the tyres] at the bottom
move the wheel until the tyre mark is at the front of the car
and measure with a tape measure...
or preferably with a piece of metal or wood with a measurement on it..
or a screw in either end.... ??
turn the wheels so they can be measured at the marks with the wheels facing rearwards as far as You can go...
then do the same at the front... Now- You need to undo the tie rod ends and turn them to adjust the toe in..
this is the tricky bit...
front
l ---------------------------- l marks on tyres
l -----------------------------l
rear
check measurement on the front then the rear
the front has a toe in of a few mms..
I cannot find the measurement... have it written somewhere?
I measured the tie rods off another car...
the short one is 92mm
and the long one is 801mm
whether this is correct I don't know...
after driving My beetle 6 years without a wheel alignment I think I will have it done professionally when I fit My front end..
Hope this helps...
I did it by eyesight once... ended up with 2 inches 50mm of toe in... lol
from centre of tie rod to the other
Aussie Dubbin ·
Sorry lee but not what i am looking for
cnfabo ·
just changing the topic a lil. but i got my top arms bent 6mm and can only get about 2.9 deg camber even with the extra eccentric adjuster....cant figure out why its maxing out as i should be able to get more then that....
HappyDaze ·
Moving the ball-joint 'in or out', will alter the camber.
Moving the ball-joint 'backwards or forwards', will alter the caster.
Signed,
Eccentric Camber Nut
Aussie Dubbin ·
Thats what im looking for Happy daze, cheers.
So moving the hole forward will move the castor to the rear, and moving the hole rarward will move the castor forward, right.
If i am getting my front end aligned what is better forward or rearwad rotation...... i am lowered and have 2 castor shims per side, (does it really just depend on what settings i am looking for)
(i'm sure the alignment guy wont have much idea about beetles, he didnt last car)
ian.mezz ·
+ caster
-camber
you have + caster so the front wheel sits forward like on a motor bike push bike etc,
If - the wheels sit back like on a shopping trolly and the car handles like a shopping trolley 🤪
- camber like a v8 race car , but to much will wear the inside of the trye.
Sorry Greg, but the adjuster does not change caster, camber only. The castor is set by the beam angle in the chassis only. The castor as you know, is the kingpin inclination. In a b/j front end, the kingpin is the ball joint pivots, the adjuster only moves during setup, otherwise all steering movement is done in the balljoints so no change to castor when adjusting camber.
HappyDaze ·
Matt, surely the caster angle changes when the ball joint is moved backwards or forwards, just as the camber angle changes when the ball joint is moved in or out?
King-pin inclination and caster angle are entirely different animals.👍
68AutoBug wrote:I didn't answer Your question
which is moving the CASTOR forwards about 10mm
steering will be better at speed...
HappyDaze wrote:Matt, surely the caster angle changes when the ball joint is moved backwards or forwards, just as the camber angle changes when the ball joint is moved in or out?
Yes Greg
I never really put it all together in My head before..
but You can change Castor and Camber with the adjusters
as the ball joints move in/out forwards/backwards
plus having the adjusters sitting next to me helps...
Sorry guy's, your wrong. The ball joint is the suspension pivot and the steering pivot. The camber eccentric positions the stub relative to the road and is locked there. The castor is the amount of inclination (angle) that the steering pivots on, projected to the road, relative to the center of the contact patch of rubber on the road. More caster is moving the line of steering towards the front of center of the contact patch. More caster means more self centering like a shopping trolley castor wheel. But moving the camber eccentric does not significantly change the castor as the steering still turns around the same balljoint pivots.
matberry wrote:Sorry guy's, your wrong. The ball joint is the suspension pivot and the steering pivot. The camber eccentric positions the stub relative to the road and is locked there. The castor is the amount of inclination (angle) that the steering pivots on, projected to the road, relative to the center of the contact patch of rubber on the road. More caster is moving the line of steering towards the front of center of the contact patch. More caster means more self centering like a shopping trolley castor wheel. But moving the camber eccentric does not significantly change the castor as the steering still turns around the same balljoint pivots.
YIKES
steering geometry is complicated...
but I see what You mean...
relative to the contact patch of rubber on the road...
I understand.... NOW..
vwo60 ·
Agree with matt, when you turn the concentric you only move the stub axle inrelationship to the ball joints, the center line through the ball joints does not change so the castor angle stays the same, only the camber changes
HappyDaze ·
Just seeing who was awake.🙄 OK, I was wrong about the caster change. The ball-joint doesn't move, does it! 😊
And Greg, do you really think it has nothing to do with kingpin inclination? It's alright mate, all's forgiven, afterall, it's that late model stuff, way after your time 😂😂😂.
and that is why they are called Camber adjusters... 😂😂😂
Live and learn... lol
HappyDaze ·
matberry wrote:😀
Matt, I'm sure you don't need it explained, but for those who are not sure, I'll give it a try:-
King pin inclination is the angle between the king pin and vertical, looking from the FRONT of the car.
Caster angle is the angle between the king pin and vertical, looking from the SIDE of the car.
For non-king pin [ball joints, struts, etc] a line through the centre of the upper and lower pivot points can be substituted.
HappyDaze wrote:
matberry wrote:😀
Well put Greg
so king pin inclination is really Camber??
HappyDaze ·
No Lee, camber is the angle between the WHEEL and vertical [looking from the FRONT of the car. Mostly, camber and king pin inclination are 'tied together', so that when the camber is altered, the KPI is also altered, but caster remains unchanged. Hope that's clear.🙄
Thanks Greg, put way better than I could have. There's that legendary experience of yours shining through again 👍👍😁
My Bentley manual says to set the notch at the front.
If you set say 1 degrees negative camber with the notch at the front and then did the same 1 degrees negative with the notch at the back you would end up with the ball joint hole being in a different position, this would affect caster or king pin inclination.
HappyDaze ·
I fell for the same trap, Steve.🙄 The camber is the only thing that will be altered by turning the eccentrics.......except, perhaps a small change in the wheelbase?
This is a very interesting thread, in that it has stirred up a few brain cells. Not sure if it has been any help to Aussie Dubbin though.
I don't think I got my reasoning across.
Forget about camber for the moment, say the adjuster is fitted first with the notch at the back and then with the notch at the back, the positioning of the hole for the ball joint will be towards the back with the notch at the front and visa versa with notch at the back, this will affect caster.
If the adjuster is set at full camber, what ever that is it will have no effect on caster, caster will only be affected at at smaller camber settings.
I agree in principal there is a small change in castor if the notch is set rearwards, as the contact patch will move slightly on the ground and as we know the theoretical kingpin doesn't move, therefore there is a change in castor, BUT, the notch is used essentially to be able to set the pair alike, and the geometry is designed around this setting being fwd's. I think you'd find the amount of change is not nearly as much as what we get when shims are used, therefore, set the camber with the notch fwd, then set toe and finally castor with shims, I generally like at least one set of shims 🙂.
Gracey ·
All this talk about eccentric camber adjusters has got me wanting to install the set I just bought.
What is the best/easiest way to remove the camber adjuster from the ball joint??
A few versions of puller will get it off. in order of preference, a ball joint breaker or pitman arm puller or a 2 or pref 3 leg may work or even easy to make a custom tool with some tube, steel a bolt and a welder.
Gracey ·
matberry wrote:A few versions of puller will get it off. in order of preference, a ball joint breaker or pitman arm puller or a 2 or pref 3 leg may work or even easy to make a custom tool with some tube, steel a bolt and a welder.
Cool, thanks Matt.
HappyDaze ·
Gracey wrote:All this talk about eccentric camber adjusters has got me wanting to install the set I just bought.
Nice move there, Gracey.......changing the subject before it got too heated.👍
Signed,
Aussie Dubbin ·
Mate, i just put my olld ones for a few months before i bought the new one and greased it up, but it still seized on. They are a bugger to seperate. If you are replacing the ball jint you can heat the nut up with a decent oxy, and give it a decent crack, otherwise i pressed mine out and there was a lot of resistance. The two 5mm plates i was resting under either side of the adjusters bent before the adjuster cracked out.
Aussie Dubbin ·
So guys its a pretty healthy discussion which i great.
I will not just be setting my camber at the notch forward position, or max camber, or min camber. I hope to have some changes over time.
let me put it another way...
If i use the hole as the point if importance/ reference point and discuss how it would change through the following clock position if 12 oclock is straight ahead to the front of the car, parallel with the center tunnel.
Left hand side;
3 oclock will give me the least amount of camber through this nut adjustment
9 oclock will give me the most camber (read as about 4 or 5* negative on my car)
My original ones used to be easy to move but now they look like part of the ball joint.. YIKES..
Aussie Dubbin ·
If i set my nut to 12 oclock i have reduced my wheel base (the tiniest bit) right?
adversley if i set it to 6 oclock then i have lengthen the wheelbase right?
So which would be preferable? Suggesting yuo set each side to the same amount/rotation...
Is it of little consequence as the major castor change has come through the angle of the car and the number of castor shims.
Aussie Dubbin wrote:Mate, i just put my olld ones for a few months before i bought the new one and greased it up, but it still seized on. They are a bugger to seperate. If you are replacing the ball jint you can heat the nut up with a decent oxy, and give it a decent crack, otherwise i pressed mine out and there was a lot of resistance. The two 5mm plates i was resting under either side of the adjusters bent before the adjuster cracked out.
mmm yeah, they can be tight, I normally use a tie rod end removal tool or press if the arms out.
