Item - 1967 Beetle rolling chassis.
Includes -
gearbox (Condition unknown)
Complete Swing axle rear end
K+L Front end
4 x Standard 5x130 Beetle rims with old tyres
Gear shifter etc (Coupler etc is all still connected)
NO ENGINE - Seized.
Sale pending
Things to note-
a couple of smaller than 5c coil rust holes in pan around passenger footwell. Rest of pan seems solid, Battery tray is solid. Usual dents etc from use, threaded seatbelt mounts have been welded either side and holes from seat belt fastener mounts have been drilled close to the tunnel on either side. Drivers side of the tunnel has a manual choke cable tube pop rivitted along its length (Easy to drill the rivitts) Hand brake works however the ratchet is broken in the lever so it will not stay locked on. Foot brakes do not work currently howeever they are complete. Pan is painted in a sound deadener covering. Passenger side has some other tube along its length.
I would like $250 ONO for the pan. I could get a lot more money than this if i split it up however I simply cannot be bothered.
Pan currently has a body sitting on it however it is just sitting there and will be lifted off.
[IMG]https://img829.imageshack.us/img829/3226/009qe.jpg[/IMG]
Uploaded with ImageShack.us
[IMG]https://img843.imageshack.us/img843/4588/118br.jpg[/IMG]
Car is located in Carters Ridge QLD (About 30mins from Noosa)
0439737762
Nicko
Anthiron ·
