johnnyb wrote:I have a 1972 Type 3 and I have been toying with the idea of switching from points to electronic. Any comments or suggestions welcome.
Also, when the engine is turned off after running for a while with the engine warm to hot, it is quite often difficult to restart the engine. The engine turns over and over and over but nothing fires!!! All I am left with is the smell of fuel. Not ideal if you stall it. This is one of the reasons I am thinking of switching to an electronic ignition. My theory is hopefully to get better spark and therefore the engine should fire.
Yes,
I have pertronix electronic ignition fitted to My beetle and it starts every time.. You never need to touch the distributor again apart from a drop or two of oil when You change the engine oil..
You don't get any extra spark unless You get a High energy ignition system...
these can be expensive ,,,
one other thing ALL VWs should have is the HOT START
modification....
this should fix Your problem...
instead of the power to Your starter motor solenoid going from the battery to the ignition switch all the way back to the starter motor..
You install a relay under the rear seat or next to the starter motor... so.. when You turn the key...
the power goes from the battery thru the relay to the starter motor... a LOT more power to start Your engine..
this is an inexpensive fix ... normal relay... $10 approx
plug for the relay with wires... $6 approx
need any more info just ask
PS: Pertronix is also recommended..
