Webers
https://forums.aussieveedubbers.com/threads/93465/webers
stifler001 ·
Hi guys,
a mate of mine gave me a set of twin 40mm IDF webers and I was wondering if they would work ok on a 1640 TP with a standard cam???
yes - 40's are good for a 1600
BUT - that said, it all depends on the jetting - and that can be changed.
I reckon they need 32 vents, 135 mains and 50 idles
Others may tell you smaller.
Have a look and tell us what is in there
vwo60 ·
I would run 28MM vents other wise you will take away the driveability of the engine, will not pull from down low.
I would go with the carbs too. I agree 28 vents for a otherwise stock 1600. Would really benifit from a good exhaust and then headwork.
stifler001 ·
thanks guys, I will check the jets and go from there. One other question, do I need to take out the engine to put the weber manifolds on?
stifler001 wrote:thanks guys, I will check the jets and go from there. One other question, do I need to take out the engine to put the weber manifolds on?
Nope 🙂
You actually need the carbs off to fit or remove the engine.
mmm.............. putting the manifolds on is easy
getting the 34Pict manifold off is the hard part
Shoot me...................... but you also need to think about Weber Windows as well
I happily cut a hole in the side to get to the mixtures and idles.
That is better done with the motor out
The other problem is if you have "short" studs.
I had some manifold studs that were VERY short and I needed to change them
stifler001 ·
thanks again! 🙂
vwo60 ·
I have 44IDF's in a 36 HP engine bay and have no problems tuning them without cutting holes in my car.
Sides ·
vwo60 wrote:I have 44IDF's in a 36 HP engine bay and have no problems tuning them without cutting holes in my car.
Really ???
Even with the windows cut in had to be a contortionist to tune my 44 IDF's... I used to get the back of the car up on stands to be able to get me arm up under the guard easily and reach in. Ditto for when changing plugs.
Am thinkin you must have really tiny hands or somethin....
HappyDaze ·
Ahaaa!......You have a Kombi, or a Karmann Ghia. [Or are you a gynecologist?].
You guy's must be a bunch of shiela's....I tune them regularly without holes cut. Mind you it makes for some interesting language.
Certainly easier with access holes, especially for #'s 1 & 3 sparkplug change.
Fit IDA's, heaps easier for access....lol
Sides ·
Hmmm.... must be a thing with different manifolds or something... with IDF's in my '70 engine bay, no way in hell would you get the idle jets out without the access holes.
But oh well - EFI now, so it's just sit in the driver's seat and play with the laptop for me !!!
vwo60 ·
I have had a 70 model beetle with 44 IDF'S with no body butchery along with the worst example with my 60 model with 44 IDF'S again and have had no problems tuning them , and my hands are big.
stifler001 ·
So I checked out the jets on the weekend, it has 140 mains, 45 idle and 32 vents. I should hopefully get the manifolds and linkages on the weekend, what is the likelyhood that it will run ok with the current jets?
Brad
It'll run, but I'd expect larger idles will be needed.
you certain they are 40's and not 36's??
stifler001 ·
Yeah, they are 40's I checked a few times, I will give it a go then change them later. just trying to get it on the road at the moment.
Do you know anywhere in Sydney where I can buy the jets / Vents?
Thanks for your help
Brad
I have a good selection, most are $8 each. You'll normally pay alot more than that. Feel free to PM me once you know what you need.
vassy66T1 ·
Get some 50 and 55 idles off Matt while you are at it.
I use to buy my jets from Carbuterror Service Company on Parramatta Road Burwood.
Just near the bus terminus
stifler001 ·
Thanks guys, Matt I will come back to you next week if the manifolds and linkages turn up this weekend.
stifler001 ·
Hi again,
So i finally received the empi inlet manifolds and went to fit them this weekend and had some issues.
firstly the studs were too short and secondly the manifolds need a fair bit pushing to get them past the tin wear, so I decided to pull the engine out to fit them.
removed the engine replaced the studs with longer ones then fitted the manifolds, all going well so I thought I better check the webers mounted ok before I put the engine back in. To my surprise the webers hit the fan shroud, I am using 40mm IDF's and I thought they should go straight on. has anyone had any issues in the past? do i need a different fan shoud?
One thing I need to point out is the the webers are quite old (manual chokes) and were originally off a mates Gemini, I would have thought that 40mm IDF's are all the same? any thoughts?
you need to put block off plates where the chokes are
http://www.cbperformance.com/catalog.asp?ProductID=518
And it'll still be tight, sometimes needing panel beating. Best with a 36hp style fan housing, but then the replacement ones still often need work for German compatibility 🙂
Not all manifolds are created equal.
1916baja ·
I actually cut the both sides off my fan shroud to get my 40 idfs on my baja, we then patched it up and painted it. looked like balls though.
stifler001 ·
ok thanks guys, I have had a look at some photos online of engine bays with the webers and most of them seem to have a seamless fan shroud, mine has a seam which sticks out, maybe its an old one. I will buy a new dog house one this week and see how I go.
If I block off the chokes does the engine still start ok?
Yep, just remove the assembly and preferebly cover the area with a blanking plate.
colin ·
stifler001 wrote:So I checked out the jets on the weekend, it has 140 mains, 45 idle and 32 vents. I should hopefully get the manifolds and linkages on the weekend, what is the likelyhood that it will run ok with the current jets?
Brad
Agree with matt, 50idles and maybe 135 mains with a 28mm vent, then with a little head work and exhaust 32mm vents and 140 mains.
Cheers Col
stifler001 ·
Hi again, looking for advice on these webers yet again. So I have the manifolds mounted and the webers now fit great (after I replaced the old fan housing) with the chokes on, but I wanted to check a couple of things. As mentioned previously in this post i got the webers off a mate of mine who had them on a gemini and one of the carbys has a straight through fuel line (as they were mounted side by side), can i just put some hose on one end and block it off or does there need to be a primary carby?
Also it seems to have vacuum outlet or maybe they're return fuel out lets (don't know too much about them) do I need to run a return line from these carbys? Anyone with photo's of a wbers setup on a type 1 would be much appreciated (as much detail as possible please).
Thanks in advance
Brad
Camo ·
Sorry, but can I conform that the webers when on the Gemini were not side draft webers. As I think you are now setting them up as down draft.
Sorry if mentioned earlier.
Kev
Gracey ·
All the Gemini's I've seen with weber's had IDF downdrafts, this I believe, was due to there not being enough room for side draft weber's.
Gracey ·
stifler001 wrote:Hi again, looking for advice on these webers yet again. So I have the manifolds mounted and the webers now fit great (after I replaced the old fan housing) with the chokes on, but I wanted to check a couple of things. As mentioned previously in this post i got the webers off a mate of mine who had them on a gemini and one of the carbys has a straight through fuel line (as they were mounted side by side), can i just put some hose on one end and block it off or does there need to be a primary carby?
Thanks in advance
Brad
As far as the fuel inlet/outlet goes, you can either block it off as you suggested or you can run one fuel line from the pump straight to that carb and then a fuel line from that carb to the other carb.
stifler001 ·
they are down drafts Camo. Thanks Gracey, I am still confused about the other outlets (i think they are returns)
Gracey ·
Can you take a picture of them, that might make it easier for people to answer the above question.
stifler001 ·
ok so here you can see the pipe at the base of the carby, i think it is a vacuum line, any thoughts?
stifler001 ·
and here you see the straight through fuel line and the return
Gracey ·
stifler001 wrote:ok so here you can see the pipe at the base of the carby, i think it is a vacuum line, any thoughts?
Looks like a vacuum port, I'd say these carbs probably came off an Alfa or a Fiat as original equipment.
Just put a rubber cap on it and forget it.
Gracey ·
stifler001 wrote:and here you see the straight through fuel line and the return
It's not really a return, it's just there to make it easy to connect the fuel lines up when the carbs are set up in line, like on an inline 4 cylinder. You just connect the fuel line from 1 carb to the other.
You can connect it up like that on your dub, 1 line from the pump to this carb and then a line from carb to carb, or you can just use a tee piece after the pump and then block the outlet on the carb pictured.
stifler001 ·
thanks for that! I spoke to a guy tonight who told me to cut the fuel pipes off and hammer a lead slinker into them to seal them. will that work, is it worth it?
stifler001 wrote:cut the fuel pipes off and hammer a lead slinker into them to seal them. will that work, is it worth it?
Crikey, a bit rough!!! Remove the barb and tap a thread and seal with a threaded plug might be a little more reliable.
stifler001 ·
thanks matt, I thought it sounded a bit rough
Klaus ·
check your emulsion tubes aswell f11 is what you want you might have a f57 in those carbs if they were on a gem , gemini's had single or dual side draught, manifolds are crap.. too many bends as i have a few off them , and as mat said plug the side holes, looks like they are early carbs with cam pump jet set up
